Recent fix
Re: Recent fix
Originally Posted by Mrmiata
Unless you can hear the starter free spinning I'd relax on this one.
Was the replacement starter a rebuilt or something that could have been marginal?
Did you ever investigate the "hissing sound"? Thinking that would be an exhaust
leak, and have to wonder if it hasn't created an issue?
One more thought... "terminals are clean"..is that just looking at them or have you
actually taken them loose and sanded the contact areas of the post and clamps to
insure a good connection?
and i could never locate the source of the hissing sound :/
could it not be the battery doesn't have enough amperage?
Re: Recent fix
Originally Posted by jabk
rebuilt starter from autozone. the terminals look clean but i haven't disonnected them.
Re: Recent fix
I was going to go test it out with a new battery today, and if that doesn't work, i was going to check the cables from the battery to the starter. perhaps they came undone.
or i could check with a multimeter and see if any voltage is even getting carried to the starter.
i just dont think it could be the fuel pump because then the engine would at least TRY to crank. and i don't believe it's the ignition.
Re: Recent fix
Re: Recent fix
just tested the voltage at the starter solenoid....11.2 volts
i'm assuming this is a bit low, and should indicate a faulty starter. i just did put in a BRAND NEW battery, after all.
so...looks like i'm getting a new starter
Yeah, I'm pretty sure your voltage is supposed to sit at 12.5, but don't quote me on that one. Did you check to see if your starter solenoid has an open circuit? Maybe it's disconnected somewhere on the inside.
Re: Recent fix
im gonna make one last effort to isolate the starter. try to determine whether maybe its the cables or something
There is a white or clear vacuum line underneath the battery, this goes through the fire wall to the heater controls. This was damaged by battery acid leaking on it in a report on here some time back.
Re: Recent fix
There has been at least one report where a battery cable was faulty due to corrosion inside the insulation and it could not be seen. This prevented full power to the starter.
atdavis2
09-21-2015 01:25 PM
