Driving along and then...
Hi all,
My father's N/A crossfire has recently been experiencing a rather strange issue. He will be driving along and then suddenly all the warning lights will come on the spoiler would raise followed by the car switching to limp mode.
I will be taking it to a shop today to see if it is throwing any codes but I wanted to put the problem out there to the forum members before I take it in.
From some inital searching I found a similar issue relating to the transmission conducter plate. Does anyone tend to agree?
Thanks,
Michael
Thanks,
Michael
Re: Driving along and then....
Hi all,
Thanks,
Michael
Thanks,
Michael
Has there been any signs of a leak?
I had my 300 go into limp mode and they replaced a solenoid. The trouble originates from the electro/hydraulic plate. A dealer may want to replace all of it. $$$$$$$
There are actually two main components that make up the unit and both will not be bad, so they could replace one unit. But only a small item will be bad and that can be replaced.
If it is warranty work they will replace the small part, but if they think they can score a big check from you they will replace as much as possible.
Thank for your replies so far. I will make sure the shop checks alternator capacity and the battery. OneHundread80 I'm lucky that I know all the major people at the workshop. It's actually a Mazda dealership but the mechanic that works there is very good and will always give it to me straight. He has saved me thousands since I stop taking the crossfires to the Chrysler dealerships. They are always happy to install any parts I have sourced from elsewhere/overseas and having taken a real interest in the crossfire and haven a genuine respect for it. Hopefully the code reader will reveal all or else it looks like a trial an error scenario...which usually translates to $$$
Hi all,
Thanks,
Michael
Thanks,
Michael
While its next to impossible to find out where a leak come in, there is a plug and low-point drain hole that the stuff can drain out.
Ok so in the end I have had to take the car to a Mercedes dealership. It threw two codes P600 and P720. They are certain it needs a new EPS/ABS Module, but they wont install it saying that they can't warranty the work because it's not a mercedes and there is a potential to fry the module. Could someone confrim this for me?
P0720 Output Speed Sensor Circuit Malfunction
P0600 Serial Communication Link Malfunction
DTC Codes - P0600-P0699 - Computer Output Circuit
This set of codes are associated with the PCM (Power Control Module)
DTC Codes - P0700-P0899 - Transmission
These set of code are associated with the Transmission and its module.
Nothing to do with the EPS/ABS. Since the codes covered 2 different modules and symptoms indicate flashing lights and spoiler deployment, maybe the RCM (relay control module) might need some attention. Just a guess but the link to the RCM module repair is a lot cheeper then ether of the other modules..... Just a guess
Seems simple enough
You could be right, but they just don't want to through parts at the problem. It really annoys me that I can't seem to find anyone that is helpful enough. Whoever came up with the name "service centre" must have never owned a crossfire
on
You might start snooping around the Transmission Control Module - look for (and I know you heard this before) water intrusion under the mat on the passenger side, and look over the TCM itself.
I have not had an auto in over two years - can't remember exactly WHERE the TCM is, but I know its in the cockpit around the shift / passenger's feet.
