second blow out in 7 days, michelin tires
Old 01-10-2005, 12:57 PM
immigrant nurse's Avatar
Question second blow out in 7 days, michelin tires
traveling to work today at 530 am, my left front tire blew out while i was traveling 30 mph. last tuesday i had a blowout on the right front tire. anyone one else? any advice please.
my car is at the dealership, waiting on a call.
Old 01-10-2005, 01:33 PM
Default Re: second blow out in 7 days, michelin tires
what are the road conditions like by you?
Old 01-10-2005, 02:03 PM
solid highway, paved
Old 01-10-2005, 02:04 PM
Dan Root's Avatar
Banned
If defected tires they should replace them at no cost.
Old 01-11-2005, 01:25 PM
Uncle_Al's Avatar
I had one blow in one year but it did occur within the first month and a half of use. Early on there did seem to be a problem with early tire failure with the Michelin tires but that problem seemed to go away by last spring. If your ride is an early number issue you may be into this problem. Otherwise if your tire pressure gauges are good then I would just call it exceedingly bad luck and find a different path to take to work.
Old 01-11-2005, 01:41 PM
It's got to be either bad luck or a bad batch of tires as Uncle Al said.. Within 2 weeks of getting my car, I got a screw buried deep in the tread (Michelin tires). I took it to the dealer because I have the tire road hazzard policy. They took the screw out and monitored the tire for a few hours. There was absolutley no leak and the tire has performed great since then.
Old 01-11-2005, 08:54 PM
Dan Root's Avatar
Banned
Question Re: second blow out in 7 days, michelin tires
How many miles on your car ?
Hit any potholes ?
How many miles on it when you purchased ?
maybe someone else hit potholes before you got it ?
Just wondering
Old 01-11-2005, 09:28 PM
thanks for all the responses. michelin have me a policy adjustment on the first tire, which helped pay for the second time.
Hit any potholes ?
i drove the route i had taken on 1/10 and found the road was washed out on the right hand side, which probably attributed to the blowout (even though i was only going 30). however the new tires on my car look better than the first ones (shinier). i found a tire dealer in inglewood california who was so very helpful.
2300 miles on the car now, 220 when purchased. everyone involved agreed this was strange to happen within 7 days. considering all that is happening in los angeles at this time, i am grateful to be alive. i think the side walls were weak, but now all is okay.
be careful out there.
Old 01-11-2005, 09:58 PM
Dan Root's Avatar
Banned
Hit any potholes ?
Both fronts ,did they pay for only 1 ?
how much did the other cost ?
Old 01-11-2005, 10:58 PM
first tire 255 plus 90 labor at the first dealer,
second dealer 27 for mount and balance, bought my own at michelin dealer with policy adjustment at 80. michelin dealer stated adjuster from michelin would not discuss second tire
xfClifford
03-03-2021 04:52 PM
PNA
11-12-2020 04:44 PM
MAXIMUM
08-04-2015 11:04 PM
nickwe21
39
07-31-2015 01:48 PM
Bayukbros
07-29-2015 10:16 AM
Quick Reply: second blow out in 7 days, michelin tires
