View Poll Results: What problems have you encountered with you baby?
Multiple Choice Poll. Voters: 83. You may not vote on this poll
Problems with the Crossfire by your build number
Re: Problems with the Crossfire by your build number
Originally Posted by afwill78
I would like to find out what number you have and also the problems you have encountered. I hate to go to the dealer with a list and not know if it is causing problems. For example, the rear hatch... A lot of people had a rattle back there...I don't. Should I go ahead and bring it up to the dealer?
Thanks ahead of time for participating!
Will
Will
Had the hatch rattle when the spoiler went up and on a dirt road. Just stopped into the dealer and they fixed it right up.
Originally Posted by catman
My John-Deere lawn tractor is belt driven, but not the Crossfire!
Must be somethin' about 'fire's....
Oh yeah... nearly 2000 miles and no problems so far.... might have the start of a hatch rattle.... I've got to turn the music down more often...
Originally Posted by HDDP
Manual Transmission ocassionaly pops out of 1st gear.
Rough idle (missing)
STILL HAVING PROBLEM AFTER 26K MILES. WONDER HOWMANY OTHERS ARE HAVING THIS PROBLEM FIREMAN/TEXAS
The ony real problem for me seems to be in my opinion, is excessive wind noise from the door windows. I did have the light behind the tach go out for a few weeks and then come back on before.
I could take it to the dealer. I have 25K miles now and hope I find all the problems before 36k.
Originally Posted by Gailwrath
The ony real problem for me seems to be ,in my opinion, is exsessive wind noise from the door windows. I did have the light behind the tach. go out for a few weeks and then come back on before
Originally Posted by FIREMAN
04 GREY/GREY 6 SPD. 1ST GEAR POPPING OUT. HAD NEW SYNCRO FIXED AT DEALER.
Auto stick had a sensor leak fixed by o-rings. But trans was over filled after the fix. I believe it was not all drained out due to viscosity. It is thick. Or he put fluid in till it showed full. and then rest drained down. the over fill leak was right on cross over pipes. number 2291
Where can I find a true list of recalls on the XF? Also, my disply on the stereo is VERY dim... is there a way to fix it or should I just replace it with an aftermarket headunit? Window switches appear to be backwards. I believe pushing up should make them go up not down... which is right which is wrong? German made so, maybe it's just the way Germans expect things to move when you push them that is...
Also, I noticed on the headlight switch, I can pull the switch out two clicks. One for the foglights, but the second one does nothing. My passenger seat is supposedly an 8-way seat, but it does not go up and down. Making a list of defects (previous owner probably never found) and will take it to the shop to have repaired when the key comes in from Germany next month.
The dim radio display and backwards window switches were a problem on very early build numbers. You should be able to get them fixed at a Chrysler dealer. Do a search and there is a post on fixing the window switches yourself if you desire. The second position on the headlight switch does nothing on US cars. It is for rear fog lights on European cars. Only the driver seat has 8 way power. The passenger is only 4 way.
You can get a list of actual recalls here:
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
So far there haven't been any actual safety recalls on the Crossfire. I don't know of anywhere you can get a complete list of service bulletins, at least not for free. You can get some of them from the NHTSA website.
