Exterior bulb light
Re: Exterior bulb light
Was everything working fine then the dash light showed a bad bulb or has it always been on since you had the car?
If this is a new indication then you just have to find the bad bulb. If it has always been there you have to find what the previous owner did which might include using non-CAN buss LED lights.
Well that's good to know. I haven't even looked at the bulbs to see what brand they are. Not that it would matter much. Thanks for your help!
It's probably the led light. I have small led's in my diy running lights. If you want to test it, go get two normal license plate bulbs replace them then if the dash light goes off/back to normal, then take your choice...look cool with a reminder that your lights are on...LED's , or ride with the standard lights...still cool, but no reminder that your lights are on..
Hi! It sounds like the same problem I had a few months back. My exterior failure lamp came on, and I couldn't find a bad bulb ANYWHERE! One day I was in front of a diesel truck at a red light and I could see the rear of my car in his enormous front bumper. I saw that my brake lights were remaining on when I removed my foot from the pedal. Check and see if your brake lights remain on when the brake pedal is NOT pushed. (I dont know if it needs to be in gear or not) Anyway, I took my Baby Blue to the Chrysler dealership, and had to have a part replaced (sorry, I cant recall the part name), it was rather costly - $1,100, and took nearly a week to get. The service mgr said it was some kind of computer part for the lights?
Hope this helps!
June
Hope this helps!
June
Hello
I own a 2005 Crossfire my exterior light comes on as well and stays on all the time. Did you ever find out what caused your light to come on ?? My car has the rear tag lights are LED but I wouldnt think the exterior light stays on even when lights are turned off can you let me know if you ever found out about this. I just got this car last Oct and I am afraid if I try to register it and inspect it it will affect my states inspection.
thanks
thanks
Hello
thanks
thanks
Hello
thanks
thanks
LED bulbs on their own need a resistor in the circuit otherwise the dash light will come on. The entire LED unit has the correction all ready made inside it.
Did you add the LEDs or did the car come with them?
Danyuhl
11-02-2019 05:18 PM
xfClifford
27
11-10-2015 10:08 PM
