Wtf 2
Old 11-15-2016, 12:31 PM
lightninle's Avatar
Default Wtf 2
Replaced the CPS, resoldered the RCM, now it won't start, it tried to fire but only for 2 seconds, now it only cranks. New RCM? Haven't checked the fuel pump and filter yet. But gas does come out of the port that you check for pressure. I don't have a pressure gauge yet to check that. 😐
Old 11-15-2016, 05:33 PM
Default Re: Wtf 2
Put the old CPS back and try again if the car was working before you changed it.
Only use BOSCH sensors.
Old 11-15-2016, 06:11 PM
lightninle's Avatar
Default Re: Wtf 2
It wasn't running is why I changed it in the first place (CPS). I did buy a Bosch. It ran for a while and died. When I replaced it, it ran for a little while driving around the block a few times. The next day only cranks fired for 2seconds then never fired again
Old 11-15-2016, 06:16 PM
Default Re: Wtf 2
Any codes been set?
Old 11-15-2016, 06:20 PM
lightninle's Avatar
Default Re: Wtf 2
No codes on my OBD2 never had a code even before it read 0 faults
Old 11-16-2016, 03:41 PM
lightninle's Avatar
Default Re: Wtf 2
Any codes been set?
turns out its the fuel pump relay. after all that stiil no codes thou. thanks
