Tool
Tool
My owners manual says I should have a tool that I would need to manually put up the top. I didn't get one with my used 05 roadster. I looked in the parts list and did not see it, I might have missed it, so I called the dealer to see if they had one. At first they didn't know what I was talking about and had to call me back. They called me back a short time later and said that the tool had changed and I would have to replace my handle for the new tool to work. Total cost for handle and tool would be $500. I will read my owners manual again since I don't recall needing the too for the handle?? They never did give me a part number for the old tool. Does anyone know what the part number is for the old tool?
Thanks,
Dave
Thanks,
Dave
on
Re: Tool
HANDLE? What HANDLE?
You need the "open end wrench" thing to unlock the decklid, and an allen wrench to lock/unlock the rear bow from the decklid. (See the owner's manual section on manually raising and lowering the top).
You can get the allen wrench at any store that sells them - I believe it is a 5.5 mm or something like that. I can't go check, because I had to park my car in the front of the subdivision because they are sealing the pavement here! I'll check tomorrow for you, if no one else chimes in first.
Do not call the dealer back or ever go there again.
Re: Tool
RE: pizzaguy
I don't know what they were talking about when they mentioned the handle. I have 5mm allen wrenches but if it is a 5.5mm I can pick up one easily and I have some bicycle spanners, one is 32mm, and the other is 18mm. I don't suppose the tool has a part number on it. In the owners manual they show a diagram of it with a number below and off to the right of it and it is 8119a19e which seems to mean nothing.
thanks
thanks
Re: Tool
The "special tool" is made to remove the front lower grill pieces for access behind, and has a 10mm open end wrench on the other end. I don't have a pic of it, but I know that some members do, and could post it. Be that as it may, a thin 10mm wrench (like one from a bicycle kit) would probably work as long as it fits between the toneau cover and the body on the roadster. the process is explained in the owners manual. A coupe has no use for the wrench end. A regular screw driver would work in releasing the lower grill pieces.
on
Re: Tool
There is a drawing of it as well, it is 1/8" thick.
Multi function Tool
Chrysler part #5140795AA There is another number as well for the second part.
MB parts #A 193 899 03 80 or #A 193 899 02 80
on
Re: Tool
RE: pizzaguy
thanks
thanks
Re: Tool
2 places in US 'say' they have stock on the wrench :
Lambert Auto Sales - 603-543-0188
Arizona Parts - (480)966-6683
good luck !
( that's the Chrysler part number : 5140795AA )
no listings for either MB part number .......
This from Welcome to the part search page
good luck !
on
Re: Tool
There, I said it, and I feel better!
You also might find a forum member thats got two or is willing to part with theirs...
on
