Roadster roof D ring mechanism
Hi all,
My 2004 Roadster roof D ring handle, has all of a sudden become loose, and when turned, makes a grinding noise.
The roof still latches and de-latches, but I guess something in the rotating part of the mechanism has let go.
Has anyone has the same problem, and what is the fix?
I guess replacement of the entire mechanism is required, but I don't want to go to Chrysler Australia, I am wondering if this part is a Mercedes part?
Any help greatly appreciated.
Cheers
Terry
Cheers
Terry
Re: Roadster roof D ring mechanism
I wanted to give a little update on my findings after I tore into the mechanism . I didn't find much help on the internet on this subject. My findings was basically you would need to replace the entire d ring mechanism in order to properly fix it. I went ahead and took it apart to see if I could some how make it work until I found a replacement . When I removed it from the car and took it apart I realized that the only thing holding the handle shaft in place from moving up and down was a washer that was pressed fit onto the shaft that holds the d ring. I went ahead and reapplied the washer with a hammer and socket. It worked great until I tried to undo the top and it just popped out again. I went ahead and removed it again but applied jb weld on the shaft/washer after I repressed it onto the shaft. Let it sit over night and it worked great. No more play on the d ring and operates as its suppose to. this is a temp fix until I can source a used one for a descent price.
here is the mechanism I'm speaking about.
here is the washer that is pressed onto the shaft
Here is the actual shaft that the washer presses on to. Can you see the ridge on top where it sits.
Here is the washer pressed on... no jb weld has been applied yet.
Here is how it looked after I applied the jb weld and let it sit overnight. Woks just great now.
Hope this helps anyone that has this issue. The convertible top section has to be removed and pulled back by the front... where the top latches to the car on top of the windshield in order to access this .
I haven't resolved this problem yet, but thanks for your replies.
I had been still putting the roof down, until the other day, when the handle went really loose, and as the top went into the down position, a piece of metal fell into the luggage area, which I was unable to retrieve. I guess it was the washer.
I went to Chrysler yesterday, and the spare parts woman had a look at it and looked on her computer, and came back with, I need the Header Latch Kit (which doesn't include the handle). There is none in the country(Australia), they are on back order, probably take months to get in, and will cost at least $1100.00 for the part only.
I could possibly buy it from the states, but I am not sure which part I need based on the diagram I got from Chrysler.HANDLE, LATCH KIT. Header, Header Release. Crossfire. Rail Header & Latch Assembly; Rail Header and Latch Assembly - 27- Body. CHRYSLER CROSSFIRE (2005 - 2008) # 05174192AA, 05140984AA, 05143011AA
Also, how easy is it to peel back the front of the top cloth to gain access?
Looking at your photo's, I was wondering if after pressing the washer back on, whether a couple of dobs of weld from a Mig welder would stop the washer coming off.
Any help of advice would be much appreciated.
Cheers
Terry
Cheers
Terry
Cheers
Terry
Cheers
Terry
As far as peeling back the top.. I just undid the screws on the underside front on the top and drilled out the rivet's ( one on pass and drivers side holding a strap that's connected to the top and to the frame.)
Twice within the past week I noticed the D-ring has been hard to turn; however, it still goes up into the pocket so I'm not sure if I have the same problem mentioned above. Is there something I need to lubricate, and if so, what would you recommend I use?
I recently had to buy an entire convertible top framework from a salvage yard just to get the rear bow molding that I needed (because that part is no longer available from Chrysler). Please contact me directly at RedDogNumber1@aol.com for more information, photos etc . . . Good luck with your repairs . . .
KDW4Him
18
09-01-2021 05:47 PM
mike28117
07-17-2015 01:59 PM
