HELP! Top Pump Assembly Cross Reference to MB
Hello All,
I read through many threads but found no answer to my question. Found out I need a pump assembly 5142638AA. Does anyone know if MB has the same pump in the SLK? If so in the 280 or the 320? I'm not paying Chrysler's part price!
I also need the wire harness as the water corrsion did it in. Since I am taking the pump out, does anyone know the part # for the "O" rings? or the part # for the harness?
THANK YOU!
THANK YOU!
Re: HELP! Top Pump Assembly Cross Reference to MB
Hello All,
THANK YOU!
THANK YOU!
This would be my guess, 170 800 00 48, maybe, maybe not.
on
Yea, our cars are based on the 320 - but the 320 is a HARD TOP convertible and it is configured quite differently.
I am unsure that the exact same pump would actually fit but I can't say for sure. Ever watch the '320's top do down? The sequence is very different from ours.
Now, this does NOT mean that the electronics don't turn different valves on and off at different times - so maybe it IS the same pump/valve unit, just sequenced differently by the Top Control Module. I just don't know.
"TopHydralics" is a guy who shows up here a LOT, he knows the system better than anyone. I'm sure he will show up in a day or two and can speak to this question better than I can.
Until he shows up, just put the top up and down manually!
on
Hello All,
THANK YOU!
THANK YOU!
the convertible top pump for the Crossfire is unique, and it does not match any other pump on the market. The Mercedes part number reference would be 1938000030, but this is specifically a Crossfire pump.
Top Hydraulics rebuilds these pumps: see http://www.tophydraulicsinc.com/en/c...ulic-pump.html
Sounds like you had a serious water problem?
You don't have to replace the o-rings on the hydraulic hoses when you take out the pump, unless the o-rings get damaged during the process. Check out g3air's thread for detailed photos of the pump removal process: https://www.crossfireforum.org/forum...ic-system.html
Klaus
TopHydraulics - Now having a roadster in the stable.. I'm REALLY glad to see you on board here..
on
Top Hydraulics rebuilds pumps and cylinders for over 30 brands of modern convertibles now, and I can apply a lot of general knowledge about hydraulic convertible top systems that way, plus I have learned a lot reading through the Crossfire service manual and supporting some Crossfire customers, such as g3air. I have been on the forum a lot when g3air ended up taking out his whole cabriolet hydraulics and created the awesome thread that is now in the stickies: https://www.crossfireforum.org/forum...ic-system.html.
Hope I can be of help in the future. This is an excellent forum, and readers are lucky to have some very experienced and willing contributors like yourself - I don't want to single out certain great contributors on this forum and accidentally leave someone out.
Klaus
xfireohio
07-20-2020 12:03 AM
mike28117
07-17-2015 01:59 PM
