Battery light on,AC went out,car won't run...
I have a 2005 Crossfire with only 44 thousand miles.
At first I noticed the AC blowing low then high. Then the following week my battery light went on,I just got a new battery 3 weeks ago. Then my ABS light went on my air bag light....then my trans seamed to be slipping....chugging down the road I lost all power... Jumped it. Started up but only went for 3 min...now won't go just had it towed.....HELP....I looked in the book it stated it could be my Serpentine belt,but it was not making any noise it's like the computer has just gone crazy. Any ideas???????
Oh this is the 2nd time I have had it in for this problem.....
Re: Battery light on,AC went out,car won't run.....
From your symptoms, sounds like your charging system isn't keeping the battery charged to where it should be. Get the car started again and while the engine is running, you should be showing 14 volts on average. About 12.6 volts with the engine shut off. If it is anything less than 13.4 volts with the engine running, you have a charging problem, most likely the alternator.
James
James
James
James
Question, I just read a old forum and it stated that if the TCM is plugged or gets wet it would run as I stated...so now I'm confused... I have it at a friends and I will let him know to ck both..I had a bad experience at the Chrysler dealer hear so I have no choice but to bring it to a local place.
Thank you,Denise
on
James
James
I agree if it is not charging you are running on battery power only. The electrical system goes nuts if it does not have enough voltage and amperage.
Keepmeinmind13
07-10-2015 01:05 AM
gobraves423
06-06-2015 07:03 PM
WindRestrictor
06-01-2015 02:31 PM
