Pulse module NOT sending signal
Hey guys,
So i decided to trace my wiring with the wiring diagram to see how power is distributed after i turn the switch. I wasn't getting signal from the clutch interlock but i got that figured out. The problem i am having now is that i am not getting any power from the pulse module to the RCM box to fire the starter. Now am getting signal from the ignition switch and the clutch with all the necessary grounds.
Did anyone have the same issue previously? I am charging up the battery now thinking maybe it was not getting the exact 12volts. Does the ignition switch have any fuses i should be worried about?
Let me know what you think.
Re: Pulse module NOT sending signal
Hey guys,
onehundred80 thanks for replying to my thread.
This question is different from the other one. Also, i haven't really had any reply to the one i posted previously so i decided to separate the questions.
Can you help me with this problem? Since i decided to dig in more to the wiring diagram so i decided to separate it.
Hey guys,
The clutch interlock feeds power to the pulse module and that feeds low amperage power to the starter solenoid.
The starter motor gets its power directly from the battery.
I could be wrong but that is what the wiring diagram shows.
I cannot see where the RCM comes into the picture here.
You are right, the wire goes to the starter solenoid. Do you know any reason why am not getting this power to the solenoid? Everything else is working fine except this. This is the reason why the starter is not engaging.
Thank you sir.
Looks to me like you have one of these :
1. a loose wire.
2. a bad pulse module.
3. a bad starter solenoid. ( did you say previously that you jumped to the solenoid and it worked ? )
The pulse module is located in the underhood fuse panel on the driver's side.
1. a loose wire.
Thanks
on
But if the RCM's "Engine control relay" does not send power to the PTCM, then there is no enable from the PTCM to the Pulse module.
Or am I wrong here, 'cause I thought we went down this path before and it was found that no engaging of the starter was traced to a broken solder pad on the RCM's engine control relay circuit.
We cannot have one system stopping all others from working or the system gets very complicated and nothing would be solvable.
I cannot remember a pulse module on my manual tranny.
I know little about the sparky stuff, so I'll leave it to the experts.
on
Dave,
I'll bet ya $20 that if you pull "Engine control fuse 1" and "Engine control fuse 2" on the RCM, the car won't crank!
I'm really certain on this - I remember we went down this road before. If I was not sure, I would let it go.... I may go pull the fuses on my car tomorrow and prove it to myself.
I'll let you know.
I'll let you know.
Dave,
I'll let you know.
I'll let you know.
I'm of to the garage I'll be back for your answer and let you know if the bet is on.
This is what am looking at in the ervice manual (although it said SRT). It seems like the Pulse module has only one input and one output to the solenoids. I got lost after it enters the PCM. Since it is already engaging the interlock switch, won't it be enough to allow the pulse module to send out the required signal?
Please see attachment.
Thanks
Thanks
The 8W-10-10 circuit comes from the 200 amp fuse directly to the ignition switch.
With the clutch interlock activated, power is applied directly to the pulse module on pin 1B.
The pulse module should then supply 12v from pin 1F to the starter solenoid for a preset number of seconds.
The 12v to the PTCM is to notify it that an engine start is in progress, do it's thing and figure out engine timing from the Crankshaft Position Sensor and the Camshaft Position Sensor, then supply spark and fuel at the appropriate times.
If you are not seeing 12v at pin 1B on the pulse module when the ignition key is turned to start, then you have a bad ignition switch, or a broken wire. If you are seeing 12v at 1B, but not at 1F, then you have a bad pulse module.
Thank you guys. You guys are amazing!
on
1 Post
This may be a dead thread, but it's the best spot, I think. I have probably posted too much on another thread, but thought this might get missed otherwise, and might be useful to someone searching "pulse module" as I was.
With basically the same symptoms, I tried a used known good pulse module and got no fire out to the starter solenoid. I traced wires and had no fire from the clutch interlock to the PCM. I temporarily spliced into the wire from the clutch interlock at the pulse module, and got fire to the PCM, and to the starter. Apparently the PCM must "give permission" before the pulse module will do its thing.
Mine was an odd failure; possible rodent damage but no evidence found. I cut the wire from clutch interlock to PCM out and spliced in a new wire, and that problem is resolved.
If you are having problems related to starting, study the FSM and ask questions. Folks here can and will help.
Michael
Michael
Like to know if somebody knows if a voltimeter reading of 10.37V from the pulse module exit 1B can cause a start hesitation. The voltage supposed to be 12. Actually the voltage reading from the exit 1F is 10.2V instead 12 volts. If someone know please enlighten me about thanks.
on
Of course there is something else. You need the enable signal from the ECM that enables the pulse module to engage the starter.
THEN, when the ECM sees the engine has reached 400 rpm (that is, it has started and it running on it's own), the ECM sends a disable to the pulse module, to disengage the starter.
I defy you to find this enable/disable line from the ECM to the Pulse Module. The pin descriptions in the service manual do not mention it, I believe that one of the pins is mis-labeled in the manual.
Here is the block diagram from the student reference, the connection in the red circle represents the enable/disable from the ECM (shown as PCM here). Note that the SLA (shift lever assembly) and other modules are connected to the ECM, it then tells the Pulse module "go" or "no go" for starter engagement.
Pizzaguy,
Have you seen my replies to your questions in the thread 'RCM' as you requested ?
Also, the only connection between the PM and ECM(PCM)is the Pink/Red wire from terminal 2A. It is marked 'sensor ground' which seems to be the mis-labelled connection ?
Mick
Mick
