Everything Dead
Re: Everything Dead
Thanks to everyone who took the time to reply or offer a suggestion. Unfortunately, I'm not very savvy with electrical stuff or even batteries, but I am convinced I need to have the battery checked and probably replaced.
What struck me as strange about this is that I was driving the car more than usual when it died all of a sudden. The first three years I had the car I was living in Western Oregon where it rains 9 months out of the year. Now I live in Central Oregon where the sun shines ten months out of the year and I drive the car much more than I used to.
Plus in the past when the battery was low I would still get some lights or at least an attempt to crank the starter. This seems like something different in that everything is completely dead.
I will have the battery checked tomorrow and post the results for anyone interested.
Thanks again for all your suggestions.
Ron
Ron
Re: Everything Dead
Ron
Ron
Re: Everything Dead
Ron
Ron
Re: Everything Dead
My problem was a dead battery. Even though I have experienced this problem before, I was surprised because the symptoms seemed different in several ways.
The one-year old battery was deader than dead, but it took a charge just fine and seems to be as good as new. I decided to disconnect it for the winter and put a battery tender on it.
I want to thank everyone who took time to offer an opinion. You guys are great. It turns out the tire dealer (Les Schwab) where I bought the battery, checked and charged if for free, so I got off extremely cheap on something I was thinking was going to be very expensive.
Thanks again,
Ron
Thanks again,
Ron
Stall, wont' start now
My 2005 Limited Roadster died yesterday while driving to a near by appointment. After sitting for about five minutes, I was able to get it to start again. It turns over with vigor, but will not run. I have tried a dozen times today to get it to start, but no luck. Any ideas would be greatly appreciated since it is my daily driver.
on
That is not really enough information for a diagnosis, but you either have no ignition or no fuel injection. ANd if the crank sensor went out, you have neither.
WHen you turn the key "ON" you should hear the fuel pump for a few seconds from under the car, faint sound, but you can usually hear it if you try. If you do not hear it, consider yanking the cover off the fuel pump relay, have a friend turn the key to on, three relays will close, then in 5 seconds, one will open. If you do not see THREE relays close, order a new RCM or send yours to DJ for rebuilding.
If you hear the pump run, I'd measure fuel pressure (you will have pressure only for about 5 seconds after turning key ON if the engine does not start).
Also,
Plug a code reader into it and read codes, if you have any P035x codes (x is any number) order a Crank Sensor and put it in. Buying one locally is a waste of time.
If you have pressure, there are a lot of suspects and the crank sensor CAN be the issue even without a code. BUT, the crank sensor usually heals when cooled off, so I doubt that's it.
Crank Sensor:
https://www.fcpeuro.com/products/mer...Lw_wcB#fitment
Everything I posted is a guess, as I try to read thru your confusing post. You got it to start but it will not run? HUH? That is like saying "it won't start but it starts".
Also,
Crank Sensor:
