2005 crossfire roadster - lft ft blinker socket
Old 11-17-2014, 01:14 PM
HAWKINSCHERYL's Avatar
Default 2005 crossfire roadster - lft ft blinker socket
HELP!!!! Nobody has this part! I need a left front blinker socket that holds the bulb. Where can I find one? Chryler or Mercedes does not have this part.
Thanks,
Cheryl
Old 11-17-2014, 01:24 PM
Trenzman's Avatar
Default Re: 2005 crossfire roadster - lft ft blinker socket
is yours missing? or not working now. There is a way to fix it by carefully bending the tabs out just a little bit or if your good at soldering you can add a bump of solder to it to raise it so it gets a good connection.
Old 11-17-2014, 02:38 PM
Well I have put new blinker bubs in it and sometimes it would work and sometimes not. I looked at the socket and it definitely has a missing connection on one side. As a matter of fact it has a hole in the silver connection. I will definitely try that soldering. CarMax wants to charge me $700.00 to fix that! That is soooo ridiculous!
Thanks,
Cheryl
Old 11-20-2014, 08:05 PM
texas t's Avatar
Smile Re: 2005 crossfire roadster - lft ft blinker socket
i may have one will ck tommorow
Old 12-01-2014, 03:32 PM
Hello there! I want to thank you for the advice you gave me about soldering the socket. It works! I am soooo happy and it passed inspection! Thanks again!
Cheryl
Old 12-01-2014, 03:33 PM
Thanks but I got it fixed. I put a little soldering on the socket and it works! Thanks again!
Cheryl
Old 12-01-2014, 05:45 PM
Trenzman's Avatar
You're very welcome that's what we are here for.
TomSRT
07-03-2015 10:42 AM
TWOFAST
06-25-2015 03:50 PM
ttosh
06-12-2015 08:25 PM
Franc Rauscher
06-07-2015 10:51 PM
WindRestrictor
06-01-2015 02:31 PM
Quick Reply: 2005 crossfire roadster - lft ft blinker socket
