Top operational noise
Re: Top operational noise
Might be....I'll have to sit and listen closer. Did not do this last year and car has been laid up all winter , so ? Thank you for the prompt reply. RR
Appears to be with bow movement.....not tonneau....and at start. Will have to sit and listen closer to pinpoint. Facing forward with noise muffled in back hard to locate. Noisy release latch ? I need more investigation. Thank you for the prompt reply. RR
That's what I was thinking. When mine first releases it makes a pop noise when the latch unhooks. White grease will make it better.
Review this thead and check to see if this could be your problem . . .
https://www.crossfireforum.org/forum...tml#post819395
2005 Ragtop
10-03-2015 03:01 PM
