Drivers and Passenger Seat Replacement
Hello people. My question is; does anyone know if the Driver and Passenger seat backs are the same when it comes to the area where the backs are attached to the bottom seating . I'm wanting to replace my drivers seat (Back) due to wear. Don't want to have it covered ; I'd rather have original material. I found a back online which is in excellent condition; only problem is , its a back for the passenger side. Does anyone know if this passenger side back will fit the bottom of the drivers side seat ? Hoping for an assuring response. Thanks.
Re: Drivers and Passenger Seat Replacement
Thanks for the info. This is for a Limited. The picture I see if the back looks identical . I just not sure if the bolts fit the same. The thread that you saw; do you remember if the person was able to use a passenger back for the drivers? Thanks
I remember reading the same thread. Someone was wanting to swap the seat backs to even out the wear, but I believe the headrests are either clocked inbound or leaning inbound. I am sure it would bolt to the lower portion, but I don't know if your seating position would change and I am sure it would not be centered correctly.
I believe they had a comparison picture of the seat backs side by side and there was a significant difference.
Hope that helps - I was wanting to do the same thing but apparently it is not to be.
Kodebuster
11-05-2020 04:06 PM
axnguyen
07-21-2015 11:41 AM
tom2112
07-12-2015 04:41 PM
