Crossfire shifter assembly
I need to replace my shifter assembly in my '06 convertible. Does anyone know of a video showing how to replace this? If no video is there a narrative on how to do this? Thanks in advance. This site has been tremendous in helping to solve many problems. Thank you all for your input and contribution!!
Re: Crossfire shifter assembly
The shifter has a selector position potentiometer in a black box on the side, its connected to the main shifter pcb via a small black jumper cable, if you have to unplug this for any reason make sure you plug it back in whilst the shifter is in your hands as its easy to bend a pin with the shifter in situe and this would cause the gearbox ecu to loose the can bus line to it resulting in not knowing what position the shifter is in causing the car to go into limp mode,
Barks
Barks
Barks
Barks
My crossfire is showing a block form in the indicator. Should be showing a P. This is causing it not to start. Could replacing the shift assembly solve my problem? There are more than 20 on eBay. Is this a frequent problem for the crossfire? Too many questions! It’s at the 3rd dealer currently. Might be hauled for scrap if they can’t fix. Have almost 1000.00 in towing bills.
Actually, when you open the door , the dash gears up showing the milage an so forth. The block as you say, stays that way until you start the car. That's when you see the "P". Was the car doing this when you bought it? Yes, then other owner can tell you what happened an when. That will give you clues ,maybe, as to which direction to proceed. What codes are coming up? The dealer's should have given you a sheet ,telling what they did and what they found. That would help us get some direction. Don't junk it, offer it to someone here. Have you tried to put it in gear using the emergency release?
Edit : So the cars not even starting...forget the shifter !! It has to run to see a P in that box!!! What are the set codes... This is very important to us to help you.!!
dpbayly
05-15-2020 10:36 AM
WonderMellon
11-02-2016 04:54 PM
ReignMan
12-13-2015 07:34 AM
232MikeSC
11-25-2015 06:55 PM
