Tire Presure Sensor Question
Got a question on these. My 2006 coupe TPS light is one and all the tires are at good pressure, so I assume one of the sensors has gone bad. Is there anyway to pinpoint which one has gone bad? Or do I need to have each tire removed from the rim and the sensors replaced? Thanks for any suggestions.
Re: Tire Presure Sensor Question
Mind you I do agree with the one has failed so replace all of them philosophy.
Or just simply disable the receiver like many have done, and go old school on maintaining the proper inflation.
Well yea, but if you don't already own one of those magic boxes, why would you pay a shop an exorbitant fee to find the failing one when you know good and well you are gonna have to have all four replaced anyway.
No offense meant at all.
Our style is sealed, he told me they have had some they took the sensors out and put a regular valve stem in and customer took home, broke them apart and changed the batteries, some reseal ed case back together, some don't, and when it was time to rotate the tires, they reinstalled sensors with new batteries.
The tire stores that give free lifetime rotation when buying tires from them, they know my tires have to be unmounted flipped and remount ed and balanced, when I go to that shop, I do not get charged.
When tire is low, it had a alarm that goes off.
This style of sensor also works great for trailers, some might need a booster so they can read signal from farther back.
Some are even set up as much for a semi and trailer and has sensors and display for each truck and trailer tire.
I have a great relationship with the Xfire tech at the stealership and he used the magic wand and walked around the car and told me which wheel had the weakest signal at no charge probably because I was having the tranny flushed and refilled which is not a cheap date. Disabling the light is not a bright option on any car without a spare tire imho
They rebuilt the OEM sensors ?
Did they put a battery in each or just one?
You say 'it' so I guess it was for just one, could you clarify please?
On my suggestion Arado took one apart and exposed the battery which was a commonly available one. He said it was not worth the effort and left it at that. If you get that changing the battery and repotting it should be easy enough.
on
My tire shop had a hand held sensor that they placed near the sensor and found out it was front passenger sensor battery was dead.
