- CLICK HERE TO GET RID OF THESE ADS -
Re: New IC Tank Design -
06-03-2008
, 04:48 AM
Great job, looks super, keep us posted on the price. Thanks
2005 Aero Blue SRT 6
InMotion USATuning (Custom)
Code 3 Supercharger Pulley/with belt wrap kit
Code 3 Heat Exchanger
Code 3 Intake Mod
Code 3 Phenolic Spacers
Water/Meth
12.33 @ 113.09
SOLD
06-03-2008
, 08:13 AM
Quote:
Originally Posted by tom2112
OK, maybe I'm blind, or just dumb, but where the heck is the regular old radiator overflow at with this shiny wonder installed?
In the third picture you will find a rectangular header/surge tank mounded on the radiator shroud. It has a 16lb radiator cap on it and you can see the overflow line running above the radiator connecting to it. This tank can be purchased at a number of places. I chose this model because it provides the most volume, fits perfectly, mounts easily and connects easily to existing hoses, was moderately priced and looked really sharp.
http://www.jegs.com/webapp/wcs/store...-1&showValue=1
06-04-2008
, 09:09 PM
Few more photos of what's going on with my SRT
SRT Enthusiast
06-04-2008
, 09:35 PM
I wish I were more confidant in my mechanical skills. If I were, I'd be following in your footsteps Brian. I assume you're putting the phenolic spacers on when you put it back together...?
THE-6
06-05-2008
, 06:19 AM
Very nice work !
Modified & Monitored
06-05-2008
, 09:02 AM
Very interesting, I was thinking of doing just that. Is that DEI Cool Tape?
06-05-2008
, 06:07 PM
That is the BIGGEST baked potato I've ever seen.
2009 328i
2005 Crossfire SRT-6
2004 Ram 1500 Hemi
1989 D50 4x4 Turbo (project)
1955 C3-B8-116(super delayed project)
SRT Enthusiast
06-05-2008
, 08:41 PM
AND a _really_ big doobie rolled next to it!
06-05-2008
, 11:34 PM
After cleaning all the blow-by out of the Intercooler - I decided it was time to add an Air-Oil separator to the PCV system. I was inspired by Brandon @ Code3 mod found here: Brandons Pvc solution
This is the Air-Oil Separator I purchased: http://www.jegs.com/webapp/wcs/store...-1&showValue=1
I found a mounting spot that worked out well and will give easy access for draining while keeping the vacuum lines to a minimum.
06-06-2008
, 12:36 AM
Okay, quit teasing - show us the whole engine already
AERO BLUE SRT6 ROADSTER
K & N FILTERS
06-06-2008
, 04:13 AM
GREAT job Brian, love the BLING. I wish I could make my engine shine like that.
'05 AERO BLUE SRT6
RENNTECH PULLEY & ECU
SL55 INTAKE UPGRADE
SPRINT BOOSTER
CLEAR SIDEMARKER LIGHTS
ILLUMINATED DOOR SILLS
AUTOXCLUSIVE-SIDESTAKES-WINDSCREEN-
GRILL-SLOTTED BUMPER GRILLS
(ALL)-CTD-INTERIOR-SURRONDS
DASH & SUPERCHARGER PLAQUE
35%-WINDOW TENT
ROTEX GOLD PADS
K&N AIR FILTERS
EIBACH PRO KIT
KMAC CAMBER BUSHINGS
S/C AFTERCOOLER FANS
1.7-60' 12.510 @ 111.62
(top speed so far 186)
'04 HARLEY SOFTAIL DEUCE
'07 STEEL GRAY GMC SIERRA 4X4
'09 GRAY CHEVY AVEO-5
'07 WHITE GMC ENVOY DENALI
06-06-2008
, 04:49 PM
Brian as said before, looks great the intakes are gorgious. Do you happen to know how they went about polishing them seems like an incredable amount of work to remove the texture and not the SRT6. I hope the system proves worth the work. Mind if I ask what you do for a living?
Enjoy the Ride...
Mike
06-07-2008
, 07:18 PM
will this setup work on a na car also. thanks Bill Fields
06-07-2008
, 07:25 PM
whoops i forgot you were talking about turbo cars. would make a nice overflow tank.
06-07-2008
, 09:12 PM
I also installed the LET HE and Johnson pump as part of my mods.
I decided to relocate my Johnson so I could keep and eye on it and be able to pull that puppy out quickly if needed. I glued a rubber mat ($4.00) on the frame as shown to prevent any vibration noise. I cut a small piece from left-over rubber mat and glued it to the inside the new bracket ($1.25) and used the existing hole and bolt to mount. I pulled hard on my Johnson - and he won't budge..
I used all stock plumbling/hoses for this job - just dressed them up a bit. The Johnson sure makes the coolant in my new tank flow.
06-07-2008
, 10:19 PM
I forgot to add the I wired my Johnson to run whenever the key is on...an essential step to help achieve the goals of my mods...
SRT Enthusiast
06-07-2008
, 10:20 PM
There's SOOOOO many jokes here, I just don't know where to begin!
SRT Enthusiast
06-07-2008
, 10:21 PM
That sounds VERY painful.
06-08-2008
, 12:04 AM
06-08-2008
, 06:32 AM
Thanks for the reply Brian, I am talking to my buddies at the bike shop I deal with, they polish a lot of aluminum...going to see if they can do mine, yours looks grt...good luck on your cooling system...
'05 Black Xfire #59312 SRT6 Roadster
Needswings Dual CAI-Code 3 SC Pulley-Sprint Booster-
LET Custom Tune-Needswings Catch Can
R1 Concepts premium drilled rotors, Axxis brake pads, Goodrich brake lines, Castrol SBF, Goodyear F1 GS D3's
12.33 ET @ 112.81 Mph (1.76 60')
'05 Blue xfire #42796 SRT6 Coupe
Parts to be installed: Dual Needswings CAI, Needswings Catch Can, Needswings separation kit, Code 3 Pulley, JR Industries Triple Pillar Pod & Gauges, New Iradium plugs...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Search Engine Friendly URLs by vBSEO 3.3.0
