Do it yourself DIY Belt Wrap Kit for less than $25
Re: Do it yourself DIY Belt Wrap Kit for less than $25
Originally Posted by waldig
Making the pulley smooth makes if smaller and you need to consider the operating RPM. You are going to make some terrific RPM speed as you get smaller the changes may suprise you, please do the math. Woody
Originally Posted by tighed1
Ok, put all of my go fast stuff back on the coupe and I have "approximately" 1/2", maybe a little less or a little more of clearance in your problem area.
Sure is fun to go fast again!
Back to running stacked. 181 and the Code 3. No more extended high speed runs for me!
The C3 is working by the way (If you saw the damage in other threads to the C3)
goodgenes, thats pretty closes. weren't there two different sets of the c3 wrap kit; 1 for stock setup which included 3 pulleys because it was too close to the idler pulley AND 1 for ASP setup which included only two pulley because the idler pulley was already small.
Am I mistaken?
Did you get the right kit?
-Steve
Am I mistaken?
-Steve
Am I mistaken?
-Steve
Am I mistaken?
-Steve
jason yours runs as close as mine did. thats why i removed it. just to close for me, i was afraid i would trash the belt. how long have you had it on? no damage to the belt?
woody what about my question regarding the pulley ribs being machined down and running the on the backside of the belt? good idea?
sorry T1, I thought he said in his post that goodgenes is using the C3 setup. But the pic does look like he's using the stock SC idler pulley, atleast I think I see ribs in there. I'm still considering doing this, but I just want to hear how people are doing with the wrap pulley and how the belt is holding up. Just want to make sure more people are getting the same results.
-steve
-steve
32, I may not be the best for your question, maybe tighed1.
If I understand you were going to just do some of the ribs. THat would be odd to me as the edges would carry all of the stress and distort the belt, again if I understand it all. Me I like bigger pullies though I can not figure how to get one to fit in the current design. My pulley saver had to go to a longer belt to fit in all the increased pulley lengths, so I again ask Tighed1 to step in on your query...Woody
If anyone is still doing this, here is a 5% off coupon for RockAuto. It's not much, but could be very useful if you plan to order more than 1, or other items also.
Code= 22501591883445
Put it in the section at the bottom that reads: "How Did You Hear About Us?" then press the apply button.
Originally Posted by 32krazy!
what i would like to do is have a machine shop remove the ribs on the pulley and bring the shoulder of the outside edges so that the inside of the pulley is now smooth were the belt rides.
Will take pics and comments later.
Ok I did this on the coupe. It's working just fine though as Woody said at a higher RPM.
maybe i can send you mine and have your guy do it. was it costly?
how did the machine shop cut it down? i spoke with a machinist and he told me if i cut it smooth there would be little to no pulley left and that the bearing was non removable. pulley poured in a mold with the bearing.
Come on you know I'm too cheap to pay someone to do something I can do myself for FREE!
