CPS replacement
CPS replacement
First off, thank you guys for a great forum.
Apparently I have the CPS problem. I ordered the new one. From what I read, it should be easy to install. I just looked at the engine from the top and do not see the sensor, and there isn't much room to work.
Can someone please post a picture or describe to me where it is? Once I put it up on ramps, is it easily seen from the bottom?
Thanks for any help you can give.
Re: CPS replacement
The attached PDF shows what you are looking for.
Click here.
Re: CPS replacement
Stand on the driver side of the engine and look behind the engine toward the transmission.
Click here.
Click here.
( I re-installed the guard when finished )
BTW: that's actually onehundred80 under that cover in his avatar - he is fed once a week through the rectangular license plate hole, that is the only break he gets from answering posts ......
Re: CPS replacement
The CPS is the main timing source for the ignition, it tells the PTCM the position of the crankshaft.
Then along with the other CPS ( Camshaft Position Sensor ), the PTCM knows the exact degree of the crankshaft.
The symptoms of a slightly bad one are engine stumbling, a totally bad one will cause the engine to die ( at any speed ) and not restart.
$40-$50 is cheap insurance, and you can carry the old one along with needed tools as a spare.
( The camshaft sensor seldom goes bad, that figures as it is the one on the front of the engine easy to get to. )
Re: CPS replacement
I dont have OBD softeare so I'm not sure if there are any "P code" any other suggestions? I do loose the SC at speeds over 65MPH or when the car gets hot, so I am changing the aux pump (has the original with 28,600 miles on the car) and i was thinking of putting in a larger air to water IC.
on
1 Post
Re: CPS replacement
Right, change out the pump. I'm a fan of the Bosch 10, mainly for plug-n-play. I'd be willing to bet after you tear down the original pump, it'll be obvious. I couldn't believe mine had failed on the black one after only 800! orig miles, but it had the exact same symptoms as your car.
umpqua rafter
12-16-2020 09:10 PM
skeet370
05-15-2018 12:57 PM
gronda
20
07-29-2015 03:07 PM
