Best AFR setup - gauge+bung+sensor
Looking to bite the bullet on my journey to go 65/181 - so I want to start loging my AFR's.
I currently only use torquepro for my engine loging. Dont really want to go Zetronix.
So I'm just looking for;
1) a dash AFR gauge I can mount discretely....
2) a good well priced probe
3) best location for the bung....
....links/photos appreciated
I might even get 2 bungs fitted, one in each pipe - EGT's might be worthwhile for future reference.
Re: Best AFR setup - gauge+bung+sensor
I am really curious about your outcome. After a lot of research, I determined the "safe" limit was 70mm with the 181 so I certainly hope you don't lose your SC.
Yes - that's possibly true, however how much time do you really spend up there...?
I'm not an autocrosser or a regular tracker - I'm looking for road performance.
The thrill of acccelerating up a back street hill at full tilt is where it's at for me.
I'm looking for 1st and 2nd gear performance in the 2-5000 rpm range.
Although I WOT - most of the time - its very difficult for me to even redline in 2nd gear (65mph).
3rd gear redline (107mph) is a very rare event.
with the zeitronix you can use your windows laptop for the display when you want it and then only bring the laptop when you want to view/record. or one of their small tweaker board display would slip in somewhere small with a little fab. you also get RPM and TPS in there for the low low cost of a couple pieces of wire to connect them.
I'm guessing this one.....?
Wideband O2 Air Fuel Ratio Sensor Module | Vacuum & Boost
can you confirm?
can you confirm?
Mine is a digital read out and I don't think mine shows vacuum. They are all good units, just want the latest one and I think that is what i have and will confiirrn tomorrow during the day. mrk Did you get the link to the injectors I bought? Price nearly doubled but they are Bosch and have the slots to accept the clips should you choose tom use them. As I have stated my O-rings were almost shot, very stiff and ready to crack. When you get to that stage let me know and i will let you know what i ran into changing nthe inj's, mark
Yeah, no gauge, I missed that but still would go with a PLX. A friend bought a cheap AFR and the numbers bounce all over the board. I checked my records and I paid $170. but had to wait quite a while to get it of stock. Must be several on ebay that have everything.
