White specks on black paint?
There are several tiny white specs on the passenger-side rear shoulder of my black SRT. I noticed them AFTER carefully washing the car. If you rub your finger over them, you can feel it. I tried picking one off with my finger-nail, but nothing gives. If photos are neccessary, I would be happy to take them. Please help!
Re: White specks on black paint?
Try a claybar over the area and see if that removes it.
https://www.crossfireforum.org/forum...hlight=claybar
I have the same thing. They will never come off. I fell it is overspray of clearcoat but after a lot of effort, I believe it is deeper in the paint than that. If a lot of the black ones have it, maybe a poor job from the factory.
Steve
Steve
on
1 Post
onehundred 80 is right. They are chips not white paint specs. What you are seeing is the undercoat. Try mrphotomans' fix. If that doesn't work you are looking at touch up paint. I would be very careful with that. check out Langka System before you do anything with touch up paint.
Pat
Pat
on
1 Post
Pat
Pat
Originally Posted by mrphotoman
they are not chips, it is defects in the paint. they are little tiny pin holes. you can not feel them, try your fingernail or if you are feeling dangerous a pin in one of the holes.
After I got mine home from the lot and gave her a good washing, I also noticed some "dots" that wouldn't wash off. At first I thought they were drops of the stuff they use to put the price on the windshields. But even after some mild rubbing with my Microfiber towel they still didn't budge. So I decided to get agressive, I took some cerium oxide (I use this on leather to polish opals with-I'm a stone cutter), and some of my good sealer wax and a felt stick (we use to polish the inside of rings with) and buffed them out oo the paint, also did a great job on some minor scuff marks on the other side of the car. Hope this helps.
Originally Posted by oledoc2u
I must have lucked out, no spots on mine the last time I clay barred her, just some chipped paint on the nose and hood...
delornut
Please do let us know how the www.drcolorchip.com product works out, I think there are many of us late model black XF owners who would really liike to know :-)
try to give you my best solution from over 25 years in the detailing industry...
I agree. It is a poor paint job. I have it on both doors on the section that angles toward the window. Looks like crap in the sun. I do not have it on any verticle surface. I spend countless hours with many different products with very little luck. They have calmed down a little but still looks bad. When I brought the car home, it looked much worse. I am afraid that if I work any more on it, I will wear the clearcoat too thin so I am afraid I am stuck with mine. I do have some on the hood closer to the grill. At first, I thought it was from being sand blasted during driving but after countless hours, I feel it is the same issue. The surface is smooth as a babies butt so I believe the problem is in the paint just below the surface.
Steve
Steve
Obviously there is more than one problem with the paint, mine are definitely chips that appear white. They are not filled with wax, I have not waxed it and I doubt that the dealer did either. After the clay bar treatment they are still there on the hood and no where else.
I can see them, I can feel them and I can put a point of a needle into them.
I think that it is damage to the clear coat and the whiteness is the fracture marks in it. I will try to fix one with a spot of clear coat.
Edit March 8th.
Putting black paint onto a chip seems to make the spot more visible than the spot of clear coat I put on a chip. After I added the spot of clear coat I carefully scraped the surface level with a sharp razor blade, it made a few light scratches that are no worse than the swirls and they should polish out OK. I will see what it looks like then.
Edit June 5th.
Polished and waxed and the clear coat came out of the chips, but the whiteness has gone from the chip.
Edit March 8th.
Edit June 5th.
