Should I buy a Crank Position Sensor
I read here and on Facebook that the Crank Position Sensor is prone to failure.
Just wondering if I should purchase one from the States to keep just in case and before it fails as it's only $50 considering I have 122,000k or 75,000 miles on my clock and don't want to be without my car as these items are much more expensive in Oz and harder to get hold of quickly.
Here are two items I am looking at. If someone can confirm they are the right items it would be much appreciated.
Standard T Series PC497T Crank Position Sensor | eBay
Forecast Products 96260 Crank Position Sensor
Re: Should I buy a Crank Position Sensor
Well, looking at both links, I do not see anywhere that the original manufacturer is Bosch.
The common sentiment on the forum when it comes to CPS sensors is "Go Bosch, or don't go home"
I personally however have been on a non-Bosch CPS sensor for well over 2 years now.
Yes! Order a Bosh sensor and keep it, and the tools to swap it in your glove compartment. It's a 5 minute roadside fix and you'll thank yourself later.
And it's on sale for $35. Your Parts Search Returned 2 Part(s)
Must add that I don't rate Bosch as I have had a number (5 or 6 items) of their home appliances, I know thats different to car parts, but all have failed early and cheaper products have continued to work on and on.......you don't always get what you pay for !!!
I do stand to be corrected by you guys who have much more experience than me and I will probably do what's recommended here.
Just looked and tried to order one but they want $70 to post so thats a no go.... Just got something else from the States recently that was bigger with only $30 postage so that is a bit excessive. Will have to keep looking. I would have paid $30 postage but not $70.
More Information for BOSCH 0261210170
Search under Mercedes-Benz> 2004> SLK320>Ignition
Shipping is about $27. Same unit price.
Thanks again, just purchased this to keep as a spare with only $14 international postage.
Mercedes Benz Crankshaft Position Sensor Bosch 0261210170 0031532728 | eBay
Also Indelibility, it should be a Bosch as its printed on the actual product and it says Bosch in the title so hopefully it is. Hope I have better luck with this Bosch product than past experience of things made by Bosch !!!
I also noted that they have sold 53 of them so I did a search on all his feedback, good and bad, and no comment came up for this item.
