New NA Exhaust Downpipes
Re: New NA Exhaust Downpipes
1. runs great, just not filtering emissions hence they are sold for off road use only on your private race track
2. yes, same scenario as #1
3. the magnaflow sounds great
4. they vary throughout the pipe in order to connect to the stock or aftermarket headers and also connect to the stock or aftermarket catback system.
on
Only if you eat a lot of VERY hot chili beans!
Seriously, your car will not shoot flames unless the engine and systems are majorly f*cked. Only way you can get the effect is to install some kind of gaseous assembly that would also ignite, at will, out the exhaust pipes. If you make such an assembly, you should mount it rearward of the muffler and out of sight. I would also make sure any leak isn't possible AND keep a fire extinguisher handy!
Idrenak
09-19-2015 08:17 PM
