Are my cats going out??
I searched around a bit and didn't turn up anything I thought was similar to my situation. Maybe I'm just really new to all this but I've had the p0410 code for some time now and haven't gotten to fixing it yet. I have to get my emissions test done soon but can't with the code on. So me being a bright guy I decided to clear the code, when I did this I noticed I have 2 more codes p0422 and another bank as well.Could the secondary air injection system problem be hurting my cats or is this just a whole other problem that I need to address? Thanks in advance for quick replies. Aaron
Re: Are my cats going out??
Read through this thread : https://www.crossfireforum.org/forum...-solution.html
1. air check valve
2. air pump relay in RCM
3. air pump itself
Fix the P0410 first, then see if the other codes come back ( and keep your cats in, don't let them out. ).
1. air check valve
3. air pump itself
1. air check valve
3. air pump itself
1. air check valve
3. air pump itself
I agree, keeping your cats in the home saves wildlife in the area. Domestic cats kill millions of birds each year. I like cats but I like the birds we feed as well.
Quick route to the solution is to determine if the pump comes on for some thirty seconds (?) or so when you start the car up from cold. If it comes on and stays on all the time at starting then the points in the RCM are stuck and the pump will get ruined pretty quickly. You should hear this easily. If it does not come on then you probably have the points burnt out in the RCM or a ground problem.
Most problems are one or other of these problems.
The check valve has been replaced. I do notice the pump on at start up for about 30 seconds. Originally I wasn't too concerned about the p0410 code but I have to get emissions done and it won't work with check engine light on.. How much experience do you need to replace the relay? I'm not very car savvy... I'm sure there is a DIY on here that I'll come in contact with soon. Thanks for the input guys!
If that does not work read the thread, your solution is in there somewhere.
FYI
When you start the engine if the coolant temperature, measured by the coolant temp sensor, is less than 80 deg F, the PCM grounds the Air Pump Relay and the pump operates. In addition, the PCM, power train control module, controls a switchover solenoid (via vacuum) that opens the switchover valves. When the switchover valves are open and the Air Pump is running, atmospheric air is injected into the exhaust manifolds through a port in each cylinder head.
From the Student Reference Book
I've been through that thread a couple times, this is where I got the idea to replace the check valve originally. I'm trying to get all of the nickel and dime things done first before I start looking at new pumps I will get in contact with tighed1 and see if I can get this going.
If it was my car I would look at the RCM and see if the points are burnt. If they are burnt I would clean them and see if the CEL situation improved. This would only be a short term cure as they would burn again. If they are not burnt you could start the car with the inside of the RCM exposed and see if they peerage OK. At least this would tell you to look elsewhere for the problem.
If the points are burnt wouldn't they need resoldered? I think this is what Ala was referring to when he suggested sending it to tighed1. I will look around and see if I can't find a DIY on taking apart the RCM... I'm not familiar with it's location or how to dismantle it.
The resoldering is done when the solenoid is replaced, the solenoid body is soldered to the mounting points on the board and the electrical contacts on the solenoid are soldered to the printed circuit board, this is what Tighed1 does.
The mystery no start thread explains the opening of the RCM, I supposed you had read that thread.
I do not know why they burn, I have had a Crossfire for 10 years and I have never had a problem. If they burn they have to be replaced, cleaning is just a temporary fix.
Sounds good, thank you for all the help/advice my xfires going into the garage for the winter as I live in Idaho and we are starting to see some snow. But either way I'd like to get this fixed before next spring, all I got to work on is the p0410 and a airbag light..
RED DOG
18
05-15-2016 02:46 PM
Kriegoff
11-28-2015 07:35 PM
HarleyBaby
11-23-2015 06:45 PM
livefreeordie
11-23-2015 01:36 PM
