Snapped the bolt on my transmission connector adapter
Re: Snapped the bolt on my transmission connector adapter
So the pentosin was for the tranny oil. Advance lists it for $19.99/ quart. The fluid chart at Advance said 8.5 for transmission fluid also, as well as the engine oil. I think their chart is off. I mentioned the differential because I plan on changing the rear differential oil, while I'm under there. I have read some threads on here that suggest it be changed at 50K miles. I am the second owner and not sure if it was ever done. Advance shows a 30K mile service for the rear end/differential.
I recommend going ahead and replacing the conductor plate and transmission connector while you are in there also.
Here is a kit from Amazon for $118 :
https://www.amazon.com/APDTY-Transmi...-benz%3Aslk320
You will also need 5 liters of fluid, this is what I used :
https://www.amazon.com/gp/product/B0..._rd_i=15724571
I used my topsider to suck out all the fluid, then marked the level with some tape on the outside of the topsider container so I could put back in exactly the amount I removed.
There will be a few ounces left in the pan when you remove it, add that to the topsider before marking the total level.
DO NOT USE THE tiny BOLT IN THE TRANSMISSION CONNECTOR TO TRY AND PULL THE CONNECTOR INTO SEATED POSITION, YOU WILL MOST LIKELY SNAP THE BOLT !!!!!!
There are uTube videos covering the entire procedure.
DISCLAIMER !!! I am a proactive kinda guy, I fix it before it fails. If you are a "if it ain't broke, don't fix it" type, just get a gasket, filter and the fluid.
You guys and this forum are all GREAT! I changed the connector, conductor plate, filter and fluid for the tranny today. Every thing went smoothly, with the exception of snapping the head off of the bolt that holds the heat shield that's by the connector. I tapped it out and put a self tapping bolt in for now. I ordered a new nut and bolt from the Dodge store that will be here tomorrow morning. I'll swap them out this next weekend. Want the original parts for it if I can. Woody's zip tie measuring stick worked as described. I cant thank you all enough. I went super slow since it was my first time messing with a transmission. Took me all day lol.
Just an update for anyone who might need this question answered in the future...
if this ever happens to anyone, you have 1 of 2 choices.
1) Drop the transmission valve body and replace the conductor plate
2) Drop the transmission valve body and retrieve the snapped screw
I chose to replace the conductor plate because the car is new to me and it has 88k on the clock (and after seeing the mess I made, I never want to drop that transmission pan ever again).
I'm including a couple of photos to show the snapped screw and the pliers I used to retreive the broken screw. It was pretty easy to retrieve.
Now, if you do replace the conductor plate, take a couple of minutes and check that all the shift solenoids are functioning properly. I used this chart to check the resistance of all of mine.
Hope this info helps someone in the future.
Currently trying to figure out how water keeps getting in my blower motor soaking rugs on passenger side. Thoughts ???
Thanks to all 😎. Richb
2 end drains blown out along with two center drains. Note sure seal at bottom of windshield is sufficient. The hunt continues 😜
Now that you have blown the drain lines out I would run water through them to be certain they drain properly and be sure the small rubber guard directly under the hinges is sitting in there properly.
I would pull the battery out and the plate it sits on. There is a vacuum hose under there that goes to the A/C blend door I believe. It could easily have been rotted out from the battery setting above it and could possible be a path for water to get into your passenger compartment.
NickHawk
01-30-2020 07:05 AM
SrWilliams
01-04-2020 01:54 PM
Freezer
03-18-2015 09:37 PM
