- CLICK HERE TO GET RID OF THESE ADS -
How do the two grills below main grill come out? -
03-09-2010
, 12:27 PM
Painting the original grill with duplicolors steel wheel paint (same as wheels and windshield surround) and it looks just really nice. In fact it resembles a Caddy grill. I like it. The removal of the grill was a piece of cake. Now I'd like to do those two little grills that live beneath the main grill....
Can anyone tell me how much of a hassle it is to get the out and then back in after they are painted.....
Thanks Popeye
Insist on common sense...
Re: How do the two grills below main grill come out? -
03-09-2010
, 12:34 PM
Thanks Popeye
They pop in and out, there are only tabs holding them in. You can press the tabs in and pull the grille out, its that easy.
07 Ltd 6speed
03-09-2010
, 12:48 PM
Thanks Popeye
The tabs or on the ends so just push to the outside of the car and pull forward. Be sure when you replace them that they lockin because they will fall out on the first big bump.
I performed that experiment myself already so please, trust me.
roadster with a stick
Former Independent Business Owner Conscripted by the Federal Government to Collect Health Care Taxes.
I've seen a lot of bad but I gotta tell ya, nobody, but NOBODY....puts ketchup on a hotdog!
powered by Eurocharged Performance Inc.
MODS: Eurocharged CAI, EurochargedTune,Catback Deletes, injectors,sprintbooster, Blinky blinkerfluid and attitude.
03-09-2010
, 12:52 PM
Don't forget that the outside temp sensor is attached to the driver's side lower grill thingy.
Roadster with a Coupe
Double your pleasure!
SRT Coupe and SRT Roadster!
350HP & 464ft-lbs and 332HP & 349ft-lbs
03-09-2010
, 01:08 PM
Quote:
Not since my "experiment" it ain't
03-09-2010
, 02:08 PM
Got down on my 70 year old hiney and looked through the grills and all I see
is about 2/5 of the grill is solid. The passenger side has a square hole in that solid part, but I see no tabs. Driver side grill pretty much the same. I must not be looking in the right place.
I thought let me see if I can get at the tabs from under the hood, no cigar there either. Can one of you lead me by the hand and tell me where to look?
Noting that 2/5 of the grill is solid, not so sure painting it without taping off those solid parts so the whole thing looks like a grill would look so good. But if I can find a way to tape off the bottom of the solid squares it should look pretty nice....
Can I see these tabs of which you speak from the front of those grills?
Thanks Popeye
03-09-2010
, 02:14 PM
Thanks Popeye
The tabs are on the grills.
Stick two fingers into the grill, right next to the center body part. Push to the outside of the car, left on the left one, right on the right one, and they will move sideways. Do a little twist, push and pull. They will come out.
Once you do it the process will seem simple and easy.
You can do this from the inside of the car by hittin' a bump, or a ramp, just right. I cannot guarrantee you won't scratch the parts so I do not reccomend it.
franc
03-09-2010
, 02:20 PM
or racoon  haha
03-09-2010
, 03:36 PM
You know, I was just in the garage wondering how they came out. I just pulled gently and it popped right out. So if you can't find the tabs you should be able to gently pull until it lets go.
Les
03-09-2010
, 03:58 PM
Quote:
Les
I went out and tried to stick my fingers in the holes, and can only get the tips in. The grills are really quite tight, although they will move about 1/8 inch. Not being able the get any real leverage front to back I don't want to use a tool and risk breaking that fragile plastic. So, think will pass on this embellishment. Perhaps if I happen to have it near a Crossfire wrench and he can take them out for me I can then paint them and stuff them back in....
Thanks for the information. The big grill was a piece of cake. ....Popeye
03-09-2010
, 04:14 PM
Actually they will come out without any tools. Just have to work with them and have strong fingers.
When I painted my lower grilles, I went back and filled in the solid holes with black paint.
First I scrubbed them with strong soap and a scrub brush. Let them dry overnight. 2 coats of epoxy primer. Then 2 coats of Duplicolor silver wheel paint. With an eyedropper, I filled the solid holes with thinned black paint. Next day I put 2 coats of satin clear.
Good Luck, James
03-09-2010
, 04:23 PM
I hit a small dog and the grill popped right off. All though I don't recommend this procedure.
03-09-2010
, 04:51 PM
I just checked in the light to see what I can add to help. The 2 tabs are on the end towards the nose of the car. No tabs on the top or bottom. If you pull in the center it will bow a little and then you can see the tabs. They are about 3/8" long and an inch apart. Once free it will swing out like a door and then you can get it out easily. All these kids that grew up on legos are now designing our cars. Everything just snaps apart and together again.
Les
03-09-2010
, 07:56 PM
That does look very nice. And the eyedropper with the black paint sounds like it would save me some taping off. Gets me back in the mood to try to get thos things out. Another fellow says that the locking tabs are toward the center and none exist on top or bottom. Thinks that bowing the grill might let the tabs clear on that one end. Tomorrow I"ll have to go out and give it another go to see if I can get them out....That really does look nice on your coupe....Popeye
03-09-2010
, 08:05 PM
Thanks. Those grilles are made out of a very sturdy plastic. You must bow them to remove them. I find it hard to believe you could break them on accident... well, not literately!
03-09-2010
, 08:19 PM
you can use a flat head screw driver...put a shop rag between the middle divider and the grille...pry a little pushing the grille to the outside, pull out...there you go....
'05 Black Xfire #59312 SRT6 Roadster
Needswings Dual CAI-Code 3 SC Pulley-Sprint Booster- LET CustomTune-Needswings Catch CanR1 Concepts premium drilled rotors,Axxis brake pads, Goodrich brake lines, Castrol SBF, Goodyear F1 GS D3's
12.33 ET @ 112.81 Mph (1.76 60')
'05 Blue xfire #42796 SRT6 Coupe
Needswings Dual CAI-Code 3 SC Pulley-Sprint Booster-Needswings Catch Can-240 Manis, Needswings Cooling separation-(Left to do)?Tune?Hawk ceramic brake pads, Goodrich brake lines,Brembo SBF
03-09-2010
, 10:35 PM
I've been kicking around the idea of painting my grille to match the rest of the silver on the car. I figured it might knock some of cheapness out of that mini van grille. How bout some pics. I would sure like to see it.
03-09-2010
, 10:47 PM
I like what you did with the lower grill James.
Don't be surprised if you see a lot more like it in St. Louis!
03-10-2010
, 04:31 PM
Quote:
Got one out this afternoon. Had some paint can openers from Lowes and I hooked one about in the middle down low, and the other one next tot he center of the front end. I then just pulled on the one in the middle and it popped out, and so held it out and pushed in on the end near the center. Bingo it was in my hand. Have to wait a couple days when rain stops so I can wash in soapy water and dry....thanks for the advice....Popeye
03-10-2010
, 07:43 PM
good for you.....get her done....and show us what you got....
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Search Engine Friendly URLs by vBSEO 3.3.0
