2005 Interior lights
Old 03-17-2013, 11:58 PM
Sonlil80's Avatar
Default 2005 Interior lights
I'm having an issue with the interior lights not going off sometimes. Doesn't do it every time but when it does I have just turn the lights off with the switch.
Old 03-18-2013, 09:56 AM
PNA's Avatar
PNA
PNA is offline
Default Re: 2005 Interior lights
Are you sure you have the interior lights switch off to begin with? There is the slide switch which controls whether the lights come on when you open the door or not. Then there is th button switch, which is usually use only for when you are in the car and need the lights t come on (map light function).
Old 03-21-2013, 10:55 PM
Sonlil80's Avatar
I have double checked all the switches and they are set correctly. Like I said, it doesn't do it every time the door is opened. I'm thinking it may be a bad door switch. Is there a good way to get the switch out without destroying it?
Old 03-21-2013, 11:16 PM
Look in the repair manual. You can find it by using the link in my sig below.
REMOVAL
DOOR AJAR SWITCH
1. Disconnect the negative battery cable.
2. Using a trim stick, press and release the retaining tab (1) at
the top of the door ajar switch.
3. Pull the top of the door ajar switch out and downward away
from the B-pillar (2), then disconnect the door ajar switch
harness connector.
Hoppy
12-07-2018 07:36 AM
ChrissyCrossfire
07-22-2015 03:26 AM
westonrose
07-14-2015 11:25 PM
Rusty475
07-13-2015 10:03 AM
Blackout317
07-07-2015 08:38 PM
Quick Reply: 2005 Interior lights
