Crossfire Dome light question
Re: Crossfire Dome light question
I think it's connected to the right side dome light and not through separate wiring. The left side notoriously doesn't work. It's often not the bulb. A little bang on it snd mine comes on. There are some fix it threads on here. Do a search. Good luck snd welcome. A few quirky things about all cars. This is one of them for the xfire. This is one fun car though.
on
1 Post
The bulbs fit into a socket that is fitted into the housing from the rear - go figure - secured with a quarter turn. You can replace bulbs without removing the socket if you're careful but if the socket gets turned it could come loose & end up in the cavity above the housing. If you take out the two recessed phillips screws & pop the housing out of the headliner you might find the socket is up there.
Power is distributed through solid metal bars running along the back of the housing - no wires.
on
Believe it or not, there are a couple of different lamp/socket configs out there. Mine were bulbs hard wired into those sockets that I had to dismantle when I installed LED laps there. I had to fabricate the contacts for both sockets when I installed them. Good luck in what your doing to the dome lights!
roychez
15
08-31-2022 01:11 AM
wbaker1970
06-17-2015 08:57 PM
gobraves423
06-06-2015 07:03 PM
WindRestrictor
06-01-2015 02:31 PM
