Passenger Reverse Light Lit with Headlights
Re: Passenger Reverse Light Lit with Headlights
Oh.. and if I recall correctly.. drop a regular bulb in there.. and the drivers side will then light up.. LOL
Also recently added led's to the overheads and have noticed they blip with the drivers window switch.. passenger window doesn't do it..
I ran into that problem a long time ago with having every single bulb on the car inside/out converted to LEDs. The circuit has a small amount of power on it when the car is on and headlights are on, for whatever reason. The LEDs pick up on this tiny spike in power and turn on since they are very sensitive. Just do what Greg said, and get a 10watt or so resistor put on the passenger side reverse light. superbrightleds.com will have the resistors your need.
Better yet, here's something that won't require any splicing whatsoever.
http://www.ebay.com/itm/2-x-1156-750...tTdoyY&vxp=mtr
2 x 1156 7506 Decoder Error Fast Flashing Fix Solution Modules | eBay
on
Can you describe what exactly you have in your rear turn signals? (Pictures, if possible) I want red, I want quality, and I don't want to hack up wiring with resistors just to put LEDs in. I hacked up some red painted bulbs (altered the offset pins) but I don't want to alter factory wiring.
Charles Moore
08-01-2015 02:35 PM
Charles Moore
08-01-2015 02:33 PM
chrisIowa
07-29-2015 03:50 PM
