headlight wont adjust
So I searched the forum and couldn't find any threads relating to my situation. When I purchased mt crossfirethe hheadlights were pointed way to low for some reason. The passenger side adjusted up to where I wanted it but the other side had an issue. As I was backing out the adjustment bolt in the center to raise the beam and it was almost where I wanted it, the beam suddenly dropped way low and wouldn't come back. I dont know the internal structure of the lamp assembly, im hoping the adjustment screw is just disconnected and didn't break. What's everyones thoughts?
Re: headlight wont adjust
Often it is because the bulb is not seated correctly into the housing of the headlight assembly of the clip that holds the bulb in isnt secured correctly
Take a look at this and then take a look at yours
https://www.crossfireforum.org/forum/524311-post1.html
Hope this helps
Gary
Hope this helps
Gary
I re-read your post and now better understand your concern.
Many here have had experience removing the headlight assemblies and should be able to chime in here with some useful info as to how it is all connected
https://www.crossfireforum.org/forum...sible-fix.html
^^^ Click this thread link.. might be your problem..
Franc Rauscher
05-09-2016 12:04 PM
2005 Ragtop
10-03-2015 03:01 PM
atdavis2
09-21-2015 01:25 PM
