Door opening problem
Hi Guys and Gals, I have a 2005 Roadster non srt model, and when i use remote to open door , the door doesn`t open properly, it seems to stick on lock on door pillar , when pulling handle on door, however it kind of half releases, and then when i release handle and pull on door handle again, it opens as normal, any ideas, it`s annoying more than anything else, Rgds , Teak
on
Re: Door opening problem
You COULD have a small leak in the air line to that door, but I'd bet the only way to fix it is to take the door panel off and inspect what is going on.
The Roadster trunk lock (the electric one that activates during Top movement) is known for not always retracting - leaving your trunklid jammed. The fix there is easy, just put the top up and down, which moves the lock again, this usually clears it.
But in YOUR case, if it is not a leaky line (and how do you find that?) I'd say it's the mechanism in the door. Maybe go in and inspect it, I've never seen the mechanism but maybe it's gotten dirty or 'dry' of lubricant. Really hard to say, but being mechanical, it should be easier to fix than an electric lock or electric problem.
(Our cars locks are pneumatic, there is an air pump in the fender in the back, behind the tail light in Roadsters and under the trunk mat in Coupes.)
waldig
10-16-2015 11:39 PM
waldig
07-15-2015 02:05 PM
