Repainting the silver frame above the windshield ?
The top silver color bracket above the windshield needs repainting. Can anyone please tell me what the Chrysler paint number is ( or any brand spray paint that matches ) . I took the car into the local dealer this morning for service and the Service Manager said he didn't know. So, I need some help....again Thanks
on
Re: Repainting the silver frame above the windshield ?
I would look up the code on a '07 or '08 Bright Silver Met Crossfire, I believe that color was almost a direct match to the windshield trim and door handles; I also heard that the Chrysler Silver PS2 was a match; Indium Silver (crossfire) 05179660AB is stated to also be close to a match.
I hope the above helps,
Dave
Dave
on
If the surround is a match to the wheels, then here's the wheel color...
XZA - Crossfire Satin Silver 05179660AB
From a previous thread about matching the surround color...
Ok guys, time to close this epic search. Ready for some laughs? I went to this guy who has an eye for color, he mixed me up a pint of PPG paint, $90. I thouhgt in the can it looked a little dark. I asked about some Lacquer thinner, which I use to clean my guns, he said a store just up the road called Colors has it. So I went and it's a PPG store. Out of curiosity I asked if he could mix paint code XZA, he looked in his book and said silver trim for a Crossfire? I had him do a pint of the inexpensive kind $27. Came home did 2 color cards, guess what? The cheapo PPG was spot on, the 90$ stuff just a shade too dark. So there you have it, go to PPG store ask for XZA. Voila! I would recommend the $90 stuff though, it's a better quality paint.
I believe that Chrysler PS2 is the same as the XZA, I'm not sure why the 2 codes but the SSB code has 2 different numbers also. No one has explained this satisfactorily to me yet.
on
https://www.crossfireforum.org/forum...paintguide.pdf
on
Edit: Just looked up the door handle on a factory Chrysler parts website. Here is the info that was given.
HANDLE. Right & Left. Exterior Door. .
This genuine part fits your 2005 CHRYSLER CROSSFIRE.
Color: (-Y3.)Exterior: (PY3.) Satin Silver.
How did you cut and apply your carbon fiber vinyl? Did you do it all by hand? or, did you use a plotter/cutter? I have a Roland vinyl cutter and if you have accurate vector files to cut the front surround I would be interested...Peace
on
Martin. I did it all by hand...just be sure to leave enough to cover the edges and enough to fold on the back of the piece...it gives it a finished look...Carl
on
on
I sure would like to see a better picture of that windshield.
Franc Rauscher
09-20-2015 09:35 AM
