Splash Shield
Old 02-22-2015, 12:10 AM
Travish's Avatar
Default Splash Shield
Both the little doors/shields are missing inside the front wheel wells the cover the fog light area on my 07. Do these look correct?
VARIOUS MFR Part # CH1251126 {#5098682AA}
plastic liner; Right Front fender splash shield
$10.59VARIOUS MFR Part # CH1250126 {#5098681AA}
plastic liner; Left Front fender splash shield
$10.61
Old 02-22-2015, 12:22 AM
Administrator / Senior Member
Default Re: Splash Shield
Those images are small buy I suspect they are not the right ones
Those little panels are basically a flat square piece of plastic with a little tab on the edge to hook it in
Old 02-22-2015, 07:51 AM
You can get a left & right set from Rob at NeedsWings for around $25.
This time put black tape over all the edges after cleaning to remove any grease.
Old 02-22-2015, 10:52 AM
Toolman's Avatar
Another idea to keep these covers on is to drill a very small starter hole in the tab while it's on the car and then put in a small screw.
Old 02-22-2015, 11:02 AM
I got a set of Taiwan made replacement shields, they have the little doors riveted on.
Old 02-22-2015, 03:08 PM
Travish's Avatar
Found them, Thanks
Old 03-28-2015, 06:20 PM
Travish's Avatar
I got these Taiwan aftermarket inner fenders from Rock Auto. $22 for both sides. They look good and fit well. One of mine was broken pretty bad.
Old 03-28-2015, 10:50 PM
JEFASOLD's Avatar
The passenger side splash shield on my car was cracked from previous owners fender bender and I lost 2 of the little panels before I found the problem. I drilled 2 holes and used plastic rivets for a permanent fix.
NeedsWings
70
03-24-2023 09:48 AM
xfireohio
09-08-2015 04:34 PM
Crossfireone
23
08-25-2015 04:56 AM
sparks81
08-19-2008 03:17 PM
ohnoesaz
08-03-2008 02:27 PM
Quick Reply: Splash Shield
