Lighted Badge
Lighted Badge
This is my version of a rear lighted badge. It's hooked up to the tail and brake light circuit. Thought it would be a cool add-on. I know some will think it's "a bit much" and kind of "ricer". Hence, that's why I have an on/off switch inside the car so I can turn it off when I want. Hope you enjoy it.
Re: Lighted Badge
Started out with buying an old emblem from Ebay just in case things didn't work out I could go back to stock emblem. Removed old wing and glued a 1/8 of acrylic the shape
of the wing to the back with a hole in the middle to house a small round led cycle light that I bought. Drilled hole in hatch to run wires and glued the wing back on, the emblem does stick out 1/8 more but is not a big deal. The hardest part was running the wires thru the hatch down thru rubber wire harness in body to the rear light to complete wire connections, wasn't too bad and enjoyed doing it.
on
Re: Lighted Badge
xfClifford
27
11-10-2015 10:08 PM
KwehCat
07-16-2015 04:48 PM
tom2112
07-08-2015 08:13 PM
