Headlight Bulb Clips Saab P/N 5400007
on
on
Re: Headlight Bulb Clips Saab P/N 5400007
The MB's that use these suckers all have this issue. Re-bend (gently) and conductive grease.
on
Aaaaand: it looks like that twist-in socket is available with flying leads. One could merely solder them into the main headlamp housing wiring harness. N'est-ce pas?
The "flying leads" would however alleviate the socket to headlight connection problems.
Where did you find those ?
on
Do a Google search for "7507 Socket"
2pcs 1156 7506 7507 1156A LED Bulbs Signal Lights Socket Harness Plugs Adapters | eBay
on
(2) Available at...
on
Or get 1156 type bulbs and grind off 1 post.
on
I said I had more investigation to do...sheesh!
I use these:
StealthBulbs.com - Invisible Turn Signal Bulbs For Your Car
Lifetime warranty, too! I've had 2 replaced within 2 days over 8 years.
I use these:
on
If you are referring to my post, no offense meant. Just trying to get quick word out incase someone ordered them and they don't work.
As for the stealth bulbs, I really like that idea, that is what I was referring to when I said "chrome bulbs". I think I saw some in red, that would be the best. Anyway, probably should be a separate thread. As for the clips the thread is about, do they fail at any time, or just when trying to replace bulbs?
I'm a newbie here and had to find a pass. side turn signal socket that was missing on my car when I bought it. I found a Crossfire owner that sold me both when his car was totaled. Now feel free to correct me here but aren't the left and right side different from each other and will only plug in on their correct side? If this is true the ones on eBay look the same and only work on one side.
I use these:
Guys
Here's a site with every type of bulb available, just scroll down the page....
Dennis
DTMenace
1157 2057 7528 2357 led bulb tail light turn signal parking brake
Dennis
DTMenace
on
Hmmm...I emailed them to see if they are still in business. That "Lifetime guarantee" can be a killer!
An alternative:
An alternative:
on
Guys
Dennis
DTMenace
Dennis
DTMenace
http://www.ebay.com/itm/like/171542408294?lpid=82&chn=ps
