LED vs HID H7
Re: LED vs HID H7
Sounds like you're using shitty HIDs to me. Have you read up on my posts regarding LEDs and HIDs in general around here? It would help you out a lot, and my LED bulb guide for the car is stickied on top of this page.
Anyway, you need to run decent HIDs in the car, and you won't have issues. Example A is Morimoto H7 HIDs from TRS in my 2004: See attachment.
LEDs do not work inside projector or reflector based housings whatsoever. Our cars utilize a variant of the E55 from Hela, which is originally an HID projector setup, only retrofitted for halogen bulbs.
There is no way for LEDs to work inside a projector made for HIDs/halogen bulbs, because the light refraction patterns cannot be the same as the HID/halogen bulbs the LED is trying to mimic. LEDs require purpose built projector modules for each individual LED chip to properly project the light. Sticking an LED bulb tower into the halogen socket will not work.
EDIT: My moritmoto kit has been running strong for over 3 years, but I recently upgraded it to the new XB style kits because of the design changes and even better output. The picture attached is the new XB units in place.
Re: LED vs HID H7
I can vouch for the Morimoto setup. I have a pair of Morimoto kits for my low beams as well. I actually have an extra set for sale over in the classifieds section. See https://www.crossfireforum.org/forum...kit-5000k.html
Still searching for something for the high beams that will match the color temp of my HIDs. There are plenty of LED H7 kits out there, but what Adrian says makes sense.
xfireohio
07-20-2020 12:03 AM
Adrian_X
11-09-2017 08:49 AM
mattnelson71
09-29-2015 03:41 PM
