Left side dome light issues
Hello everyone!
This problem has been upsetting me for a while. It started with the left side dome light not being as bright as the right side despite the same bulb.
Then all of a sudden the left side is always out. I went ahead to take the assembly out and when I rattle the left bulb back and forth it will come back on but as soon as the assembly is reinstalled and the cover added it goes out again.
Obviously has to do with the metal "line" that is running around the housing of the assembly and provides contact surface.
Has anyone fixed this issue and can give me some pointers? Love this car but man oh man that whole dome light assembly sure is flimsy!
Nick
Nick
Re: Left side dome light issues
Unworthy for a car of this quality!
Is it the same assembly in a Merc SLK? I was already thinking about ordering a new one but I assume they are expensive and as long as I don't see anything broken I won't order a new one! But it would be nice to finally see something in the car at night with the dome light on!
My big problem is that I haven't yet figured out how to fix it!! If something worked for you let me know please!
I took my assembly apart & found that the bulb socket assembly was not fully seated on the two power runners. This was giving intermittent contact. Make sure the contacts on the bulb socket assembly are making good contact with the power rails. The socket assembly requires a quarter turn. The rails could also be secured by melting some styrene plastic where the plastic pins protrude thru the holes in the runners.
Stan
Stan
I also experienced this problem where both bulbs worked until I reassembled the dome light into the position, then the left light was either dimmer or did not work at all. After several removal and replacement attempts I found that as RED RUNNER (no relation that I know of) suggested, the bulb socket was not fully rotated and seated. Play with it until you are SURE it is inserted correctly and has been rotated a quarter turn to the lock position. All should be well . . .
I thought I had solved the problem on my dome light but the drivers side bulb went dead again. My latest repair is to add fresh solder to the contacts on the bulb socket. I also scuffed (cleaned) the rail where the bulb socket makes contact. The rail seemed to have some oxidation. If this doesn't fix it I will be soldering wires between the bulb socket & the rail. So far the solder job has fixed the problem.
Stan
Stan
My issue turned out to be broken plastic around the socket, I ended up soldering the socket contact to the metal runner to ensure contact. It has been working for a while now, but I am searching for a replacement that is not $896.00 (Dealer replacement price).
Red Dog - you have both roadsters and a coupe, can you verify that the dome light assemblies are the same for me?
Thanks!
Thanks!
on
