New headliner, pretty easy to replace.
Replaced my headliner around a month ago and forgot to share pics about it lol. Used a gray that matches the light gray from the slate interior set of colors.
Getting the headliner out and back in was the hard part.
Re: New headliner, pretty easy to replace.
×Crossfire1× (02-02-2023)
on
Ok cool, thanks. I'll tackle it this weekend.
Also may want to lay down some cloth on the dashboard area. When taking my headliner out I wound up causing a few small scratches in the plastic near the odometer(just behind the steering wheel), where the fiberglass ceiling panel "rubbed" a bit during removal.
Also I believe the instructions on the forum mention prying off the front pillars, I did not do that. After removing the back trunk pieces and disconnecting the pins holding the ceiling up, I was able to just slide the front lips of the ceiling out of the tops of the front pillars. Leaving the front pillars in place also gave me an extra hand(was doing the job solo) when putting the top back in, I was able to rest the front of the ceiling on top of those while I put the pins back in on the backside.
on
Depends on how you define "Professional"...
Personally, NO ONE cares about your car as much as YOU do, no matter HOW much you pay them. I'd rather spend two weekends working on my car than PAYING someone who may or may not do it well enough for me.
on
You can take out the headliner and take it to a shop that would recover it. I went to a couple of dealerships, and asked the collision shop (or the service department) who they sub this type of work to. Got a guy that did mine for slightly over 60 bucks and gave me a 1 yr warranty. Put it back in after a couple of days later (letting it set fully). That was over a year ago, it is still looking fantastic! So, if your patient, and study up on some of the posts (and find a shop that will recover it with a form of a warranty), you can get it done pretty inexpensively.
Pulled the headliner out of my SRT over the weekend and took it to an upholstery shop I have dealt with for years. They had two levels of fabric in the right color. One was a smooth foam backed fabric at $85 installed and the other a lightly textured foam backed fabric that was a near perfect match to the original at $125 installed. Went for the textured. I'll post how it looks when I pick it up. Thanks to everyone who has posted extra tips after doing their own, it went quite smoothly.
Picked up the headliner today, it looks good. They did wrap the fabric over to the back and glued it in place all around the edges. Won't have time to install it till the weekend and will also wrap up some other installs I didn't get done last weekend.
Started the removal process on my headliner today. Everything up front (map lights, Tire Pressure Module, sun visors) was easy to remove & disconnect. Not real comfortable getting the A-pillar interior trim loose. How hard do I have to pull to get these loose?
The cloth material itself was a lost cause. I was able to get it pulled out with the headliner still in the car. Interior trim at the C-pillar came away from its upper mount rather easily.
FYI - the 2 fasteners securing the map light module require a T20 Torx bit to remove. Don't remember whether anyone stated that before.
Background: new member; I just got a 2005 Crossfire Coupe Limited with just over 30K miles. I'm very happy with car but the headliner is drooping on the driver's side. I debated just trying to get the liner loose on that side and spray adhesive into it but it seems like removing the whole headliner isn't that hard. No one has mentioned whether the rubber window seal needs to be removed. Is that necessary? More pictures of the process would be great! Thanks in advance for your help!
Natemo
Natemo
Natemo
Natemo
The rubber window seals are not removed. I found that removing the whole glove box door made the removal and install a snap.
Also remove the b pillar trim before removing the large grey sails behind the quarter windows. Start by moving the seat belt to the side where it comes out of the black trim under the quarter window - you will see a gold colored screw remove this first - then start lifting the black trim from the front it is held on with clips that are close to the quarter window.
