Dead Pedal
Old 06-18-2016, 03:17 PM
Utah12's Avatar
Default Dead Pedal
I have seen reference to the removal of a dead pedal from the Crossfire to either extend leg room or to add a more substantial one. I do not see any existing dead pedal. Seems to be just carpeting in that area. Are there pictures of either mod? It would be nice to have a custom aluminum one like I added to my E46. Is there something to mount to?
Old 06-18-2016, 11:50 PM
Padgett's Avatar
Default Re: Dead Pedal
Under the two plugs there are the mounting screws. Is just a plain plastic piece.
Old 06-19-2016, 12:45 AM
Utah12's Avatar
Thank you. I never looked close enough. Seems rather cheap in a car such as ours. What is underneath if you remove it? Enough backing for a nice aluminum dead pedal?
Old 06-19-2016, 02:34 PM
Utah12's Avatar
I have read on the forum that a couple of inches in leg room could be gained by removing this. The aluminum dead pedals are thin and could be added and still result in additional leg room. I would like to see what other members have done. Pictures?
Old 06-19-2016, 05:32 PM
Padgett's Avatar
Just bought an accelerator pedal cover from FLAPS.
Old 06-19-2016, 05:43 PM
Utah12's Avatar
Did you reuse the same holes and screws for mounting the dead pedal in the pic?
Old 06-19-2016, 07:58 PM
Padgett's Avatar
Yes, otherwise I would have used flat heads.
Old 06-20-2016, 02:25 PM
Utah12's Avatar
Checked today. No dead pedal on my Crossfire. Was it an option? I would like too add one to rest my left foot on but now I'm not sure what I can screw into.
Old 06-20-2016, 04:40 PM
They were on the later models only I believe. Look like crap though from what I see.
Save
Old 06-20-2016, 04:45 PM
Utah12's Avatar
Save
Agreed, looks like a after thought. What I really need to know is if I can put screws into that area to mount a meaningful aluminum dead pedal.
Old 06-27-2016, 12:07 AM
JEFASOLD's Avatar
The best dead pedal that I've seen belongs to DTMenace, it matches perfectly and is solid. looks like a factory fit.
Old 06-27-2016, 06:58 AM
DTMenace's Avatar
Thanks Jim for the complement, mine is securely attached with heavy duty Velcro to the carpet and it does not move at all. Attached is an old photo after the install.
The direct match is a gas pedal from a Dodge Neon SRT4. Check Ebay or your local boneyard for the part, Dodge no longer sell the pedal only, but sell the pedal with the attached arm for $90+. The floor mat is partially covering the dead pedal.
Dennis
DTMenace
Old 06-28-2016, 10:43 AM
There are multiple Mercedes (AMG) style dead pedals on ebay. I purchased the one that ships from Australia for $40.00. I feel it's the best match. Looks like OEM fit and finish. Other options range from $19.00 and up.
Mercedes AMG Dead Pedal Footrest A45 C63 CLA45 GLA45 W204 W164 X156 C117 | eBay
Check it out.
Old 06-28-2016, 05:43 PM
Utah12's Avatar
Check it out.
How did you attach? Velcro?
Old 06-28-2016, 07:17 PM
Yes, the pedal cover comes with Velcro on the back side to attach to your carpet.
Old 06-28-2016, 07:53 PM
Utah12's Avatar
I like it! $40 though is a lot. I already blew my budget this month on some leather stuff from the UK (brake handle and door handle covers).
Old 08-04-2016, 09:08 PM
Utah12's Avatar
Did you go with the edge or try to align it with the pedals? On my standard the angle of the bump is different than the pedals. The downside to aligning with the pedals is that part of the dead pedal will be hanging off slightly.
Old 08-05-2016, 02:49 PM
Dead Pedal - sounds like a good name for a group of guys that look like this:
Old 08-06-2016, 06:38 AM
Check it out.
I'm thinking strongly about getting one of these. Looked really good in your car.
Old 08-06-2016, 11:00 AM
The dead pedal in my 2007 doesn't look at all like the one in your picture. It is attached with 2 screws, but the one in my car is completely flat. There is no hump-back to it. Not sure now I want to replace it.
Quick Reply: Dead Pedal
