Oil burning off?
Oil burning off?
I changed my oil and filter yesterday. After 5,600 miles since my last change in November of 2007. I took out about 6 and 7/8 qts. I did have some leaking during the cold weather (Not a quarts worth) which subsided when I started driving in the warmer weather again. Has anyone noticed that much usage of oil between oil changes with 5000 mile intervals? I current have 24K on the car.
on
Re: Oil burning off?
Hi Stan, I've never measured the exact amount that comes out. I use the topsider which holds a little more than 8 qts. and the 2 times I changed the oil it was filled to the top. Was the oil light on? It should have been on if it was that low on oil. My oil light came once after I changed the oil and it was a little less than a 1/2 qt. low.
on
I haven't changed my oil yet. I bought the car in the end of February with 6000 miles. Since then I've put just over 4000 miles on it. I will probably change the oil next month before the car goes into storage for the winter. I thought I read that 8 1/2 quarts was what was needed re the oil change. I suppose I could take out the owner's manual and check, if it wasn't raining right now.
Bob
Bob
on
Bob
Bob
any ideas?
on
Originally Posted by Cross+Fire+06
Stan is it difficult to change the oil? Where do you buy your filters? I am tired of paying 140 per oil change... i have a friend ( ex BF) who will change it for me... but it seems to cost almost the same for the filter.. 30$ ... and 8$ per qt oil?
any ideas?
any ideas?
on
Jen,
Just to re-iterate what they said. I purchased the Benz, paper filters off eBay for some ridiculously low price. I bought a 3-pack. Each filter comes with new seals. I see no need in getting a more expensive fleece filter because I don't drive the car too much and I don't drive it hard on a full-time basis. If I had an SRT-6 I would use the fleece filters.
I also check in the automotive section of Walmart every time I go to one. They will sometimes have the Mobil1, 0-W40. Usually only 6 or 12 qts. at a time. So you have to be diligent about looking for the stuff. it's usually around $5.60 per quart. I always buy 9 of them.
You will have to jack up the car to get to the drain plug. The oil change is easy to do after the first time. Really, the hardest part is jacking the car and removing the engine cover from the bottom of the engine. The messiest part is removing the filter from the stem and changing the seals on the stem.
My garage is open to you if you would like to come over sometime to do the oil change.
Stan
Stan
