Front Turn Signal Light Bulb Socket
Re: Front Turn Signal Light Bulb Socket
The Fiat part number for this is 9406215468.
Google this number and you find it is used on a lot of European cars.
It can be found here (CLICK- Lithuania) or (CLICK) or (CLICK) eBay UK, there must be other cars that use them.
This part accepts a PY 21 W bulb (amber) and the socket size is BAU15S
This looks like the Butterfly socket we have.
Valeo makes parts for lots of car not just MB.
List of bulb types.
The links I provide are for the correct part and mention Fiat, Citroen and Peugeot. [/QUOTE]
I have received these parts, put in a bulb and tested them, they work and fit 100%.
I got mine from Lithuania which was the cheapest price of them all, not China which is amazing. The parts were made in France.
They cost £5 (US$8) each and were delivered in under 10 days.
on
Good catch.
on
on
Our recycling attempts are far behind theirs, we do have PP, PE etc. on our containers and so on. I would imagine that as it has glass fiber in that plug resin it is not wanted in the recycled polyamide bin. I think probably most if not all parts on the car give the content.
on
Can you tell me Valeo phone number? That's exactly what I need.
on
on
[QUOTE=Bjm65;891745]
You need no part number just order the part from the eBay site that appears when you click on my link.
I think you have missed something here, you do not phone Valeo you order it from eBay UK CLICK.[/QUOTE
With the Peugeot part number? Or the one on the socket and God Bless for responding.
I just ordered my second socket from ebay.co.uk
Indicator Bulb Holder For Peugeot 207 307 607 807 621546
https://www.ebay.co.uk/itm/Indicator....c100039.m2059
First one worked out fine...
I should have ordered two to begin with.
From ebay.co.uk
From ebay.co.uk
Well got the parts this past weekend and installed yesterday and worked like a charm. So I have 3 left in case something goes wrong with the passenger side with two in reserve. Got mine also from Lithuania, took about 2 weeks to get with the holidays.Now for the rubber piece under the passenger mirror that looks like spider webs now.
Attachment 32312I have had a problem with mine on the drivers side, one of the contacts got weak and would not hold the connection. It finally broke all the way off and like everyone a replacement is not easy. I will see how long my fix holds. I found a pen with a metal pocket clip that fit in the channel and cut a piece longer than the gap, once I verified the connection with my multimeter and soldered it in place. I built up the bridge with more solder so it made a solid connection in the housing.
