Performance Differential Gearing
Re: Performance Differential Gearing
I think it's incredible all the time, money, and research that you've had to put into this Jim. After all, you do have a life beyond your Crossfire. Don't you? I'll have to talk to you later about the hood.
I just hope there are enough NA cars owners out there that would like to get their cars into the 13's. I know this should be a popular way to go with many SRT owners.
Let me ask you this. Assuming everything works out the way you plan it, do you think an NA car could get by with a 3.73 and an "open" rear end with some good DR's at the strip, and decent street tires for the street?
Of course I've got "limited slip" in my AMX, but sometimes the way it hooks up at the drags, I think I could possibly get by with an open gear on the street . So I'm thinking with the better weight distribution in the Crossfire, (and less torque) it should respond in a similar manner. What do you think?
Good luck with your testing, I hope you don't break anything, and try not to tear up too much pavement.:
yes is what i would say to your question """ Assuming everything works out the way you plan it, do you think an NA car could get by with a 3.73 and an "open" rear end with some good DR's at the strip, and decent street tires for the street?"" jim
not sure as we went to a friend's yard and spent 6 hours measuring and found 4 of them,, then we had to machine off the flange where the ring gear bolts on, and on another one we had to add a spacer to the ring gear to get the ring and pinon to line up,, then we found a couple of set of gears that bolt on, no mods,, so to answer your question, the one thing i do know is it came from a Mercedes. yes we are using a crossfire diff housing. when all is done i will post all the part numbers and how we did it.. we are also looking at the ford 9". and making that a bolt in,,, that is all i can say about the Ford 9" at this time. jim
I was always qurious the measurement difference between the 4 mounting bolts on the r170 rear k member and the k member in the challenger, pics they look really close, but if parts fit by pictures we would have alot more options.
pashitst weekend had my birthday party at the track the same day they had the Orlando speed world Dragway -2022 Lucas oil D2
i was not signed up but being i was having my birthday party there, i got in one run they were running 1/8 mile. now i have 123000 miles on the car ,NeedsWings heat exchanger, down pipes , headers, lower pulley my stock pulley turned down,,,with 'r's tune, with Matt doing all the work,, street tires open rear, i ran 1.899 -60',, 5.327-330' ,,, 8.131 eight mile, speed 87.79 ,,1000' 10554 this is in the srt6 in one eight mile I will run 1/4 mile in late Oct. WE WILL SEE
thanks to Matt, Rudy,and Rob this will be a fast srt6 maybe it will become a srt6+2 or as we say a crossfire V8
jim
jim
amx1397
04-25-2015 11:52 PM
