CrossfireForum.org
- CLICK HERE TO GET RID OF THESE ADS -
Go Back   CrossfireForum.org > Technical > Technical & Modifications
LinkBack Thread Tools
Old
Default Correct dynomode? - 12-29-2009 , 01:23 PM
We want to visit a dyno day with a few Crossfires. What i did read so far there seems to be problems with the traction control so the cars dont rev up over a certain rpm or hold power back.
Some talk about pulling fuses, others about pressing a button, also there seem zto be differences between the transmissions?
So is there a "correct" way for that dyno mode (what fuses?) so we dont waste our time and cant get the cars dynoed once we arrive?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Sponsored Links
Old
apkano's Avatar
Life is random...so am I.
Default Re: Correct dynomode? - 12-29-2009 , 07:41 PM
Try to arrange for a 4-wheel dyno and you won't have any problem's at all.
Old
Default Re: Correct dynomode? - 12-29-2009 , 07:43 PM
eurocharged has it all figured out if you are going to one of theirs...no worries...
'05 Black Xfire #59312 SRT6 Roadster
Needswings Dual CAI-Code 3 SC Pulley-Sprint Booster-
LET Custom Tune-Needswings Catch Can
R1 Concepts premium drilled rotors, Axxis brake pads, Goodrich brake lines, Castrol SBF, Goodyear F1 GS D3's
12.33 ET @ 112.81 Mph (1.76 60')
'05 Blue xfire #42796 SRT6 Coupe
Parts to be installed: Dual Needswings CAI, Needswings Catch Can, Needswings separation kit, Code 3 Pulley, JR Industries Triple Pillar Pod & Gauges, New Iradium plugs...
Old
32krazy!'s Avatar
Default Re: Correct dynomode? - 12-29-2009 , 08:03 PM
esp off and do the runs in 3rd gear to 5800 rpm and you should have no issues
current mods
eurocharged custom "tony" tune
c3pulley, needswings modded devil horns,sl55 intake, k&n filters, needswings oil catch can
180 pte tsat, tighed1's supercooler, separated coolant system
-10* fan mod
delimited nitto 555r dr's
akebono pads blue motul fluid
drilled and slotted rotors front and rear
visual mods
oz bottecelli 18" wheels!
3 lamel grille, audio 10 cd player,led tailights, zaino finish
ideas welcome!
340.7hp / 331.9 ft/lbs. torque
et 1/4 12.716@110.19 mph
Old
bmorgan's Avatar
Default Re: Correct dynomode? - 12-29-2009 , 08:21 PM
Quote:
LOL.... That will surely take care of the problem!
2005 SRT-6 Roadster
• Eurocharged Dyno Tune • Code 3 Pulley • NW CAI • Lowered Suspension • Resonator Delete • Ansa Muffler • 255/50/16 MT ETs on 13lb CLK Wheels
Best 1/4 12.222 @ 114.07 - 1.804 60'
RWHP-337.3 Torque-344.2
Wish List: • Lexani LX10s • Meth Kit • Separated cooling system • Billet Grill • HID Headlights • Interior/Exterior LEDs • Clear Side Markers
Old
tighed1's Avatar
Default Re: Correct dynomode? - 12-29-2009 , 08:23 PM
With an automatic pull fuses 17 & 18.
Took me a few tries runs to get a good run cuz the trans kept down shifting.
I think I had to rev to around 4k then get on it to get a good run.
I think....
Roadster with a Coupe
Double your pleasure!
SRT Coupe and SRT Roadster!
350HP & 464ft-lbs and 332HP & 349ft-lbs
Old
apkano's Avatar
Default Re: Correct dynomode? - 12-29-2009 , 10:09 PM
Quote:
I'm serious. Some chassis dyno's will have a mechanical linkage to turn the front wheels as well as the rears. The whole issue with dyno'ing our cars is the front wheels remaining stationary while the rears are spinning. Since I have no idea where the OP is from or where he's going I made the blanket suggestion that he tries to arrange for a 4 wheel dyno.
For some reason, my car won't do a dyno pull to redline no matter what you do to it. Pull fuses, certain gears, even using the STAR system in dyno mode doesn't work. If I could get to a 4-wheel chassis dyno there would be no problems.
Old
bmorgan's Avatar
Default Re: Correct dynomode? - 12-29-2009 , 10:33 PM
Well, I learned something new today. I had never heard of one before. Thanks
Old
TVT_DESIGN's Avatar
Default Re: Correct dynomode? - 12-30-2009 , 04:21 PM
Then you're doing something wrong. We've gotten every year (04-08) manual and auto to do full red line runs on both 2 wheel and 4 wheel dynos.
STAR is not necessary for this either.
Your source for:
74mm NA Throttle Bodies
Rebored SRT6 Throttle Bodies
Cold Air Intakes
Custom ECU Tunes
A Friend in a Time of Need
Dual Exhausts
NA kits from 215hp to 265hp!!
And lots more!
TVTDesign.com
(732) 649-9597
All Forum Members receive 10% off all orders!
Old
apkano's Avatar
Default Re: Correct dynomode? - 01-03-2010 , 12:33 AM
Wasn't just me..........Rob was there as well as a few Mercedes guys......nobody could figure it out.
As I said before......there's no problem if you arrange for a 4-wheel dyno, that spins the front wheel negating the whole issue.
Old
tom2112's Avatar
SRT Enthusiast
Default Re: Correct dynomode? - 01-04-2010 , 03:53 PM
That's weird. I was very worried about getting mine dyno'd, but I attended an dyno day with a whole bunch of Neons. The shop doing the dyno looked at me like I had 5 heads when I told them about the dyno issues experienced by folks here in the forum. They said to let them give it a shot and if I wasn't happy with the dyno, they would refund my fee.
They didn't have any trouble, and it dyno'd all the way to 6200 rpm on a single axle dyno. I asked them what they did special, and the guy said 'nuthin'.
Maybe my ECU tune helped in this regard. I don't know. Apkano, is your's tuned?
Old
apkano's Avatar
Default Re: Correct dynomode? - 01-05-2010 , 11:21 AM
Not at the time. We were just testing the difference between stock intake and the NeedsWings CAI, no other mods.
Old
TVT_DESIGN's Avatar
Default Re: Correct dynomode? - 01-05-2010 , 01:24 PM
You can run these cars to full red line on a single axle dyno. We do all our local testing on a Dynapack for tuning accuracy and have zero issues taking it to red line.
Old
goodgenes79's Avatar
Default Re: Correct dynomode? - 01-05-2010 , 03:11 PM
i used a DYNOCOM single axle e-brake dyno, without a tune. Third gear pull from 2500rpm to 5800, no shifts up or down, just shut down when it hit limiter.
* If you find yourself in a hole, the first thing to do is stop diggin'.*
2005 Crossfire SRT-6... SSB coupe
Spectre Dual CAI w/ K&N filters, Code3 S/C pulley, resonator delete, E55 H/E, coolant seperation, DIY belt wrap... otherwise stock
soon: system monitor/datalogger, tune
want: lighter hood with heat dissipation vents, Billet Grille
328.5_hp/347.7_tq (Dynocom)
1/8: 8.37@87.91
1/4: 12.78@111.16
Old
apkano's Avatar
Default Re: Correct dynomode? - 01-05-2010 , 08:15 PM
Yup..... for years we've all been making up this grand story of a 5800rpm upper limit just for fun.
Old
tom2112's Avatar
SRT Enthusiast
Default Re: Correct dynomode? - 01-06-2010 , 03:22 PM
You're not alone, Apkano. Steve Hellums had the same problem. I know a couple others too, but I can't think of the names. So that makes me wonder what is different about your cars vs. the ones that dyno ok...?
What's your build number? Maybe you have an earlier ECU version than the rest.
Old
Default Re: Correct dynomode? - 02-08-2010 , 08:23 PM
I'm serious. Some chassis dyno's will have a mechanical carburetor linkage to turn the front wheels as well as the rears. The whole issue with dyno'ing our cars is the front wheels remaining stationary while the rears are spinning. Since I have no idea where the OP is from or where he's going I made the blanket suggestion that he tries to arrange for a 4 wheel dyno.
Does arranging a 4-wheel dyno really settled your problem? I am wondering how this thing worked?
Old
Infinite's Avatar
Default Re: Correct dynomode? - 02-09-2010 , 03:48 AM
Im curious as well because doing a run to 5800 is pointless...
The road I walk is paved in gold
To glorify my platinum soul
Old
apkano's Avatar
Default Re: Correct dynomode? - 02-09-2010 , 06:39 AM
Quote:
I'm wondering how of all the people who quoted my text....you're the only one who feels the need to edit it to say something that it clearly does not.
Old
ProjectMayhem's Avatar
Default Re: Correct dynomode? - 02-13-2010 , 02:01 AM
My car wouldn not dyno under any conditions as well until i got a tune.
2005 Graphite SRT-6
12.081@114.865 1.775 60ft,custom 3inch intake, 178 ASP pulley. Port & polish throttlebody, Eurocharged custom "Tony" tune.
2009 GIR SCSS Sport tuner champion.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2004 - 2008 XF Industries LLC
Search Engine Friendly URLs by vBSEO 3.3.0
