Interior Door Pull Handle Repair/Retrofit with Pics
Re: Interior Door Pull Handle Repair/Retrofit with Pics
Thanks again. From what I have been able to see, it looks like 2 small screw drivers or a special tool is needed to depress 2 clips that position it in place, however, with my current state of disability, I an going to need to get a helping hand in order to give this a try. I can't imagine that it would be glued, things need to be repairable, locating pins or clips would make more sense. If I find the answer, I will post the solution.
Hello gentleman. Need some help. What is the preferred tool to use when separating the stainless trim on the interior door pull. Mine is on pretty good and I do not want to damage or scratch it. I am upgrading my door speakers. Any suggestions would be appreciated and I thank you in advance.
This is a great write-up! I realize this is an old post. New here and not sure if this is the correct place to ask. I am considering buying a 2005 coupe. No problem with the handle attachments, but the chrome plating is flaking up on both driver and passenger sides. Anyone know if they can be rechromed or refinished? Thanks.
I now have a leather cover for the handle. I put sticky Velcro tape on the back face over the ragged edge before that and it seemed to work OK.
I got a pair of leather covers from a UK firm that they make for the Crossfire, they are held on using Velcro, they look good and cover the handle from one end to the other.
The plating just comes loose and replanting would cost too much I think.
Cover it up as it can give you a nice cut.
If you look at the seam on the bottom with a mirror you can see that the lip that is folded under the rear lip has some notches in it. You can pry it apart carefully at those gaps. I carefully used a thin screwdriver to separate the two halves. Separate the two halves evenly a bit at a time. Easy does it is the way to go. It
Hi Everyone! I'm happy to report that the door handle fix I did on my Crossfire has been problem-free ever since I did the repair many years ago!
Thanks again to our mod, onehundred80 for making my writeup a sticky!
As far as everyone else who've done the repair to their door handles, It still makes me happy to hear that the writeup helped fixed the issue and saved you nearly $300. from having to buy a new replacement handle.
waldig
10-16-2015 11:39 PM
rocketrage
10-07-2015 05:00 PM
waldig
07-15-2015 02:05 PM
