Loss of power
Re: Loss of power
Some similar postings describe an issue with CPS
https://www.crossfireforum.org/forum...tml#post851581
Also, a posting here with BAS ESP light and acceleration issue indicated a wiring harness issue with throttle body.
https://www.crossfireforum.org/forum...elerating.html
One more for your....points at possible vacuum line issue. Owner had broken connector to inter cooler.
https://www.crossfireforum.org/forum...ess-power.html
Re: Loss of power
I haven't had this happen in awhile, but while testing at the track, I have had the throttle pedal come unhinged and ride up on the mounting. This will result in less that full throttle. I know this isn't your problem but may be a problem in the future if you do many full throttle launches. Might try a throttle reset. See if it helps.
