- CLICK HERE TO GET RID OF THESE ADS -
Re: Do you want a Keyless Entry Alert Tone? -
03-18-2010
, 06:57 PM
Quote:
Originally Posted by Toddy
Finally got around to installing this yesterday, when I took my roadster out of winter storage -- it may be March, but it's been over 60 here for a week now! Woohoo! Anyhow, awesome mod, corfire, just fantastic. I bought the 60 buzzer, but once you get it sealed inside the fuse box and then shut the hood, it's very quiet. I'll probably mount it outside the box at some point. Still, this is a huge improvement over, y'know, dead silence! It's audible if you listen for it, and certainly a lot better than a horn honk. Very classy kind of sound.
Thanks again. Love this forum, just awesome advice here for our great cars!
I have the 273-079 to try. Hope its not toooo loud. Ron
Thanks all for your help! Ron
04-16-2010
, 11:42 AM
THNX! one of the easiest, simple mods on here. I have never been happier....
04-16-2010
, 11:57 AM
Quote:
Are you sure about that? Cuz there are a ton of things that I could recommend that would definitely raise the bar for you a lot
04-16-2010
, 02:15 PM
How long does it take to do? Is this a real simple install? Want to do this over the weekend. Are there any instructions with steps? Ron
04-16-2010
, 02:44 PM
Quote:
Instructions with pics are in post #2 of this thread. Takes about 10 minutes.
04-16-2010
, 05:50 PM
Installed a radio Shack 273-079 and very low and poor sound. Than we tried a 273-0071 chime but wiring looked strange but still poor sound. Maybe one of you can check the wiring on this it has a red + black- and a blue to a switch to black. The best was the 273-0060 which I think was the 273-060 and sounds the best but still a bit low. Mounted the 60 on top of the fuse box with Velcro. Very Cool! Ron
04-16-2010
, 06:45 PM
Quote:
Scored a set of service manuals on freebay for 45 bucks delivered. Already have the downloaded manual, will say it is much harder to read then my other "print" manuals for my other two vehicles. Might change my mind after I receive the printed manuals I just scored, never know.
The circuit should easily power another relay coil, after that the only concern would be the contact limits as to load. Wiring is easy, there are enough access points to the fuse center to slip the two (relay coil) wires in/out to connect to the relay coil terminals (either like the one post where he opened up the relay and soldered directly to the terminals inside the relay and drilled holes in the top for the wires to protrude or some other way to connect to the pins with an assurance they will not loosten nor corrode). Care less what anyone else likes/doesn't like about horn sound, happen to like the audible of the horn for an acknowledgement for lock/unlock. My Camaro uses the horn to audible the lock/unlock, have had other vehicles with the same, tend to want to go with it for my XF.
Actually found another post that demonstrated the alarm siren upgrade, and didn't like that sound either. Will do what pleases me, like I said in an earlier post, those who like your quick inexpensive mod are happy with it. Am concerned if they do not have a reliable tight connection, the mod may not work later (at best) or might cause some corrosion (at worst) due to the dissimilar metals used and the constant heating/cooling/humidity present in the area. Not to mention, if they do not return the wiring to its factory state when they sell it, I hope they include the wiring upgrade in the owners manual when they pass the car on.
Don't know how many times I can say the mod your extolling is a good one for many. It isn't a good one for me. I did my own research, tested your "piezo" buzzers (and quite a few more) heard the factory upgraded repair siren, and choose the direction I am taking.
How much does it cost to put the new siren in? Where does it go? does it sound much better than the mod? Is it louder? Do you just order the siren replacement from Chrysler? Thanks Ron
04-16-2010
, 08:53 PM
I've been using a 273-059 mounted outside the fuse panel since I ‘invented’ the mod over 2 years ago, and haven't had any failures or problems. Some have used the 273-060 that is a little louder, but neither one is loud. I understand that the siren replacement has become quite expensive, and in my opinion replacing it appears to be much harder to do than my mod.
Red 04' 6-Spd Manual Coupe
All Good! See Links.
81' Corvette (Sold)
All Original
04-16-2010
, 09:01 PM
Quote:
And your mod is perfect for my use. I do not need a loud blaring sound. I just want a non-obtrusive audible to let me know my door actually locked without having to look for the lights to flash. This was my first mod when I bought my car, and still one of my favorites.
04-17-2010
, 07:11 AM
Your mod is fantastic and seems just fine for me.
Now, whats the next simple mod thats excellent like this one? Ron
04-18-2010
, 11:30 AM
Installation is complete with the 060. Fantastic!
Thanks for sharing this cheap and easy mod.
'05 Aero Blue SRT-6 Roadster, 12k miles, #49365
Johnson CM30 Pump, Rotex Gold Brake Pads, Adamesh Wind Deflector, Alpine CDE-9845
04-18-2010
, 01:47 PM
Glad to see that some have found and are enjoying the info again. Every now and then someone finds it, installs it, comments and brings the thread back in view.
04-27-2010
, 10:29 AM
Went to radioshack to do this yesteday. 3 dollars for the buzzer took 20 minutes to get it the way I wanted and tada! This was super easy thanks!
05-17-2010
, 07:57 PM
Installation is complete with the 060. Fantastic! The instructions were perfect!
I didn't tell my wife, RadaratNBC, so I'm interested to get her response!!
2005 Crossfire Roadster Limited
Color: Aero Blue Pearlcoat
Disc Italia Hyper Ceramic brake pads
Goodyear F1 GS-D3
Production #: 59,498
Attended: Fall 2009 Tail of the Dragon GTG
Baby's Owner: RadaratNBC
05-21-2010
, 03:10 AM
Did this mod today, and it look less than 15 minutes. I used the 273-075. Its a little too quiet for me so I'm going to experiment with some louder ones.
06 Crossfire Base - 6 Speed - #2511
05-27-2010
, 08:42 PM
That was an easy 15min. Very cool mod. Now I beep with the best of them.
JohnB
05-30-2010
, 07:50 PM
Did it ! with the 060 ! thanks for this upgrade !
super easy even with my 2 left hands with 5 thumbs each...
06-04-2010
, 08:18 PM
The easiest mod ever. Took about 5 minutes after convincing my mechanic son that I did in fact know what I was doing. Went with the 060 as well. I just got the car last week and was a little nervous about getting under the hood. Thanks to Corfire for great step by step and all of you for the follow ups.
07-07-2010
, 08:10 PM
Thanks Corfire... I just performed your mod yesterday at lunch and it worked flawlessly. I went with the 060 buzzer and mounted on the inner fender well adjacent to the box gave just the right volume! The tone of the buzzer is just unique enough to sound totally custom. Thanks again!
08-31-2010
, 07:25 PM
Thanks for this mod. Took about 5 minutes to install.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Search Engine Friendly URLs by vBSEO 3.3.0
