Foggy Crossfire Headlights
Re: Foggy Crossfire Headlights
I know this thread is old but I purchased a 2004 Crossfire (2nd one I have owned) and to pass Maryland State Inspection I need to purchase a new passenger side headlight so now there is a very noticeable different with the drivers side.
I'll be purchasing one of the kits listed above and I'll let you know my findings when I tackle the job this coming weekend.
If it ain't broken, do you want to sell it ?
Sucks because that was an expensive part
The condensation should have been an easy fix. Sometimes they leak around the seal that is between the lens and the body, silicone would have fixed that.
Keep the unit and repair it if you still have it.
Maybe you had a badly fogged lens, inside and out or a bad bulb or bulb setup.
Has anyone thought about removing the headlamps to restore them, my main concern is damage to the surrounding paintwork.
Looking at the manual, it is a matter of 4 bolts, and a wiring harness.
Mine need doing badly, and I am concerned the cops will give me an unroadworthy sticker, which will force the issue.
I got a quote from one of the local panel shops, to do the headlamps, respray the windscreen surround, and to repair a small gouge in the rear lower plastic bumper which the Mother Inlaw did when she borrowed it, for $500, which isn't too bad I guess, I might go that path, but I wold like to do the headlamps myself.
Cheers
Terry
Cheers
Terry
Cheers
Terry
Cheers
Terry
Just mask off the surrounding areas with the blue masking tape and be careful with the rotary polisher when you are close to the edge.
HINT: Once you have them crystal clear, put some Xpel or 3m protectors on, that will vastly prevent fogging in the future.
on
Go for it! It is pretty easy, just time-intensive. It takes me ~ 1-1.5 hrs/side.
1 to 11/2 hours would be 1 to 5.5 hours ?
( The 5.5 hour mark includes 2 six packs of beer )
Just messing wid ya, Max. I know you meant 1 to 1.5 hours
Like to meet others in the area to hook up with...give me a shout if you need any info.
Cheers
Terry
Cheers
Terry
Hey Salgaigh. I had the same issue for awhile. I tried everything. Headlight restoring products, extreme bugging, headlight restoring pro , you name it. In the end, I fixed mine when I had them customized. The issue was a buildup of oil residue inside the lens. When they cut the lens apart to customize them, I made sure to ask them to clean and buff the inner lens. No amount of polishing or sanding will work, if the issue is inside the lens.
After using my drill with a buffer attachment plus a kit I got from Harbor Freight and sanding for over an hour, and taping the finish around the lens so I wouldn't damage the paint, I gave up. I am going to replace the headlamp lens and I'm hoping it is not a real big job.
I just found this replacement lens for $51.40
http://www.discountbodyparts.com/cat...BoChl4QAvD_BwE
I haven't bought it yet and I am going to search through the Forum to find out if I can handle the replacement myself.
http://www.discountbodyparts.com/catalog/feeds/Replacement/Headlight/REPC100107.html?dbpcid=gglpla&gclid=CjwKCAjw_IPcBR AjEiwAl44QkU1faJqQt-g0nfP8ttgps8eF3Ol6_PbSZztUMw8YPbjanEzfpauKIBoChl4Q AvD_BwE
If it was a good fit you would be a hero and talked about in awe. But .......
