How to Repair Relay Control Module (RCM) - (Mystery no Start)
re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
if the solder iron you picked up is an always on unit and not a gun you should be ok with 25W, if it is a gun you may need a hotter iron. I used a 50W gun and had the module back in my car within thirty minutes. Check your solder, ideally you want a rosin flux-core, as an acid core can damage the circuit board if you apply too much. As previous posters have said make sure you are not melting the solder on the iron, but on the leads themselves while still applying heat to the leads. I cleaned up the old solder with an emery board prior to soldering (one of the leads had too much built up already on what was blatantly a cold solder from the cracking). The leads run to the huge pins that power the module so it will take quite a bit to heat them up. You are correct that you DO NOT want to connect all three leads as that will short out the board and you will have to purchase a new one.
As a side note if anyone near Wilmington NC needs or desires their RCM re-soldered or just inspected feel free to PM me.
on
So I just finished doing the repair and my soldering is pretty bad.. I put the rcm back in the car, connected everything again and now the BAS/ESP light is on.. is that related to the rcm or is it just from having the battery disconnected?
Very likely just the battery being disconnected. Turn on the Car, turn the steering wheel full right to lock, turn it full left to lock and then center it up. Hopefully the light will disapear. Good luck.
I think I need some help. Same issue, car will start and then not start. Radio comes on etc., no start, then radio powers down. Battery replaced a couple of months ago. Not sure what I am looking at under the hood, so can I order a relay?
Are you sure the battery terminals are tight and clean?
yes to tight and clean battery. When I go to start the car... key into ignition turn to the right crank to start up, does not turn over, dashboard lights up, radio comes on and then all is quiet. I'm a girl with no skills... only thing I have been able to do, is program my own key. Love this forum. Looked into that black box next to the battery and that was overwhelming... yikes.
It's not a major ordeal.. might find a member near you to help out?
OK...you have jokes..! I went and looked at that black box again, thinking I'm in the wrong area, as it has too many wires and things going on for me. I took a picture of it, and still not sure what I am looking for or at. So with that said, I will take it to the shop next week, and not the stealership. I will search the forum for a diagram, so that I will at least know what it looks like, plus I will sound like I know what I am talking about at the shop. The forum has taught me well... lol with a big thanks to you all.
on
I'll be swapping out my RCM tomorrow or Tuesday with a brand new one if you want me to take pictures...
Now if you want to attempt the soldering to fix your current one instead of getting a new one, you'll have to ask someone else because apparently my soldering skills are seriously lacking... Which is depressing since it is something that little kids learn to do well at summer camp but I somehow can't get the process down right...
I'm Guessing you have searched and found the "Mystery no start" thread?.. if I recall correctly there are pictures there.
As you stand by the battery, the one closest to you is the BCM( Body Control Module ),
then the PCM ( Powertrain Control Module ), and last the RCM ( Relay Control Module )
All of them have tons of connector wires, but the RCM has the least.
It can be removed without disturbing the other 2.
MAKE SURE YOU DISCONNECT THE NEGATIVE BATTERY CABLE BEFORE DOING ANYTHING !!!!!!!!
I am getting excited. When I purchased this car, I was not expecting it to be a perfect car with no issues. I did my research on this fourm.
However, I made a deal with myself that if I bought it, I would try to fix a minor problem when possible. You guys have inspired me to
try it. The pix are of great assistance, since I am a visual... and those wires are now not so overwhelming. @Mrmiata, love it and 247 is a great
distance, not to close and close enough for a day road trip. @alaxfire, since I don't want a tingle or my hair any curler, understood- I will
disconnect the negative. @rayth, you are correct no sausage fingers. Now and finally @Tighed1, you are my hero. I will first attempt to ship and
swap, and since I am girl, I can change my mind and maybe I will have to work out a loaner. So to everyone, thanks for your support, knowledge
etc.., get the tissue, I am about to cry... feeling the love. I will print out everything and later this week or this weekend coming and tackle that RCM. Pizzaguy is close to the beach, now that could be another option. Stay tuned, I will post as I work my way to it. Thank YOU all!
As you point out, you are girl .....
If I were you, I'd be mighty careful about pizzaguy, he has quite a rep around here.
He just embarked on a new adventure with a lovely co-worker, ignoring all advice to the contrary given him by forum members.
He is like a fine wine : extremely enjoyable, but best consumed in small quantity .....
( Just joking pizzaguy )
Follow the directions at the start of this thread and you won't go wrong.
If Pizza can do it (ask him about his oil changing skills) you can do it!
Will PM you contact info should you decide to mail it.
I will inspect, repair then test on my car.
Return in the mail very next day Priority mail.
$5 for the repair (beer money) $5 for return shipping.
If you want the "Me so Horny" mod please include an extra $5.
That reminds me.
EVERYONE.
Don't spend $15-$20 mailing these. They fit in the padded flat rate envelopes and ship for about $5.
That reminds me.
EVERYONE.
on
That reminds me.
EVERYONE.
That reminds me.
EVERYONE.
Tighed1 is one of the best guys to help you out here in this forum. He's helped many, and for only a thank you or a pittance. He'll steer you straight for sure. Those connectors could be a little confusing, some have those swing to click/lock so just watch how they come apart and you'll be fine. If I am not mistaken, there is also a little clip/tab that you have to move out of the way to get the RCM module out so watch for that as well. Thanks tighed1, for the help you provide the membership!
