trunk rattle
trunk rattle
Hey guys, I tried searching the forums but I couldn't find what I was looking for. There is a rattle coming from the trunk door, sounds like its coming from right under the wing. Anyways sounds like something got loose and it's driving me nuts. Is there a way to remove the plastic so I can find what is making the noise? Any help is appreciated thanks.
Re: trunk rattle
Coupes are known to have the hatch rattle at the latch. Try putting a couple of wraps of electrical tape on the latch post to see if this solves the rattle. Also there is a rubber stop on each side of the hatch that can be adjusted. If you don't have a coupe, well I dunno?
Re: trunk rattle
Re: trunk rattle
Originally Posted by spikehound
Yeah I have a limited coupe. It's not the latch because I can hear exactly where the noise is coming from and it's under that plastic
If it's not that then taking the lower hatch plastic off to check the spoiler mechanism isn't hard. 1 screw in the handle and then carefully pulling the plastic away from the hatch panel gains easy access to the spoiler motor. Check to see if something is amiss there.
Good luck.
on
Re: trunk rattle
After about 2 years of having 3-4 wraps of electrical tape on the latch post, I started hearing a little "clunk" at slow speeds over certain types of road irregularities. The underneath side of the tape around the latch post had been eaten through so to speak. Peeled it all off & replaced it.....clunk gone again.
Re: trunk rattle
Re: trunk rattle
Originally Posted by Joliet John
There are no adjustments which will eliminate the latch rattle.
Re: trunk rattle
Just extend the bump stops at each side of the rear hatch, this raises the position of the hatch enough to eliminate the loose (rattling) latch when closed. When adjusted correctly, the rear hatch will shut nicely with a slightly firm action and the latch will not rattle as it has a little tension in it
Re: trunk rattle
The only noise I hear from the back is the Trunk Monkey, a few bananas quickly stops that though.
trunk monkey on Yahoo! Video
Too good to forget so I dug them out, sorry.
2005 Ragtop
10-03-2015 03:01 PM
